Integra 4 gauge wire install
hello folks im looking for people that have had power wire installed in there 94 integra 5spd. While looking under the hood i don't see a very easy to reach hole in the fire wall to run the wire from the battery to the cabin. Just wondering if and integra owners with wires installed could shed some light on where there power wire was ran thanks for any and all help.
Modified by gsrjrsc at 1:30 PM 3/20/2006
There are a 2 good places to run power into the car, [on an LS anyway] if you look down the drivers side of the batt. about 3-4 inch's below the batt. there is a unused hole, [about 1"] covered with a "dummy" grommet, and if you look behind the batt. you will find another much larger oval shaped unused hole, also covered with a "dummy" grommet.
Remove the grommet and cut a round hole in it a hair smaller in diameter then the power lead you are running, reinstall the grommet and run the lead.
94
94
fryman
Aug 30, 2009 07:48 PM
imadigitalgod
Audio / Security / Video
Oct 21, 2006 07:35 PM
