Installing Remote Starter ( Need some help)
Old Sep 29, 2013 | 01:30 PM
Mr.Civic's Avatar
Icon2 Installing Remote Starter ( Need some help)
Hello everybody, I need some help from those that have gone trough this before. I bought a remote starter and vehicle security system for the wife's car.
It's a PolarStart unit, model: PS-3155
So, I've done some research on the wiring diagram and have made a conversion file in excel to have everything ready on the install day. I will be installing this unit with a friend, hoping to put this in before winter hits here.
There's some blank spaces I need help in filling, things I'm slightly not sure about. Such as:
12- YELLOW ........................ (+) Glow plug input 3 - "not sure what this is, and weather the car has this option."
11- GREY ............................ (-) NEG. Door input 3 - "same goes here, where would I use this?"
10- WHITE ................. (-) GROUND when running 3 "now I know the regular ground can be hooked up to the body, but what about this one? it says ground when running"
9- PURPLE .................... (-) EXT. TRIGGER input - "what is this?"
Overall, everything is pretty straight forward. I'm confident I can install this unit without any problems, I have wiring and correct soldering knowledge. And I'm sure I can do a good job on this. So please don't recommend a professional installer, I can't afford it. Plus it's a great learning experience. Thanks in advance for your help.
Here's the wiring diagram for my wife's vehicle (2000 Honda Civic SE) :
http://autostart.ca/wiring_info_seri...=Civic&ye=2000
Here's the link to the quick installation .pdf file of my remote starter unit:
http://dealers.automobilitydistribut...%20english.pdf
Here's the link to my excel file, with the conversion guide:
https://docs.google.com/file/d/0BxEN...it?usp=sharing
Old Sep 29, 2013 | 08:58 PM
Axatax's Avatar
Default Re: Installing Remote Starter ( Need some help)
I'm seeing a "3" after each item, not sure if that is intentional or if some special character is not being displayed properly (I only mention this because it changes the context of items #1 and #2 - responses assume it shouldn't be there).
No connection. For a diesel.
Your dome light wire.
No connection.
No connection, unless you want to integrate with an OEM keyfob/keyless entry. Grounding this will activate the R/S.
prabhakarglv
Audio / Security / Video
Feb 16, 2014 08:19 PM
Jaydeep
Oct 15, 2009 09:09 AM
Morning Call
Dec 18, 2004 01:42 PM
GSRacer1
Nov 30, 2002 03:31 PM
