Ignition Screws
Old Nov 1, 2010 | 09:01 AM
dem0nk1d's Avatar
Default Ignition Screws
So I just got back into the whole Honda game, and I’ve been thinking if any companies out there make security screws for the Honda ignition switch. As you know this is pretty much the weakest link with thieves.
Old Nov 4, 2010 | 09:55 PM
nilleo's Avatar
Default Re: Ignition Screws
are you talking about for the back of the electronic switch? I looked for some at the local home depot and lowes, but didn't find any, pretty much gave up there as I lost interest. They have an uncommon threading with security screws, your best bet would be to rethread them and use different threaded and size security screws.
Old Nov 5, 2010 | 07:55 AM
dem0nk1d's Avatar
Nilleo: Yes I'm talking about the Phillip screws that keeps the ign switch to the ign column/rack. This is pretty much the biggest flaw in honda's security. You can put as many kill switches etc... in the car, but there hasn't been anything made for this flaw...
Old Nov 5, 2010 | 11:14 AM
nilleo's Avatar
With that switch and no other protection, yes you could still start the car, but you can't disable the ignition lock without turning or removing the tumbler. I totally understand your point, but even if you weren't able to remove that cover off as easy, someone could just easily come in with their own switch ready to go, unplug the original, plug in theirs and start the car. The best solution is to have layers of security, have a back up plan AFTER the switch wiring so even if some one were to bypass the screws or the wiring, they're still SOL. Extra layers will also increase the chances of defending against a variety of morons that try to take your car, not all will try the same methods.
I'd say a bigger, if not biggest flaw were earlier gens where the key cylinder in the door could be turned with most other Honda keys
Old Nov 9, 2010 | 08:36 AM
dem0nk1d's Avatar
oh that still happens till this day. with the lock situation, on the doors. Just jiggle the key and it opens. Retarded. Oh well uncle Honda makes great cars but lacks in security.
Old Nov 11, 2010 | 06:26 PM
1998GsRIntegra's Avatar
And we all wonder why they are the most stolen car in america. Hmmm
Old Nov 12, 2010 | 08:49 PM
confidence's Avatar
if your key cylinders are worn the jiggle key is easier to do. take out your cylinders and look for grooves in the outer housing. If you have them your cylinders are worn out. Honda sells a rebuild it and its pretty cheap. Someone on the civic forums has a very good how to thread on doing just that. i think he gives the parts numbers as well. You will have to search for it
as for random metric bolts like that you want to look at Fastenal in your town (if you have one or a local equivalent) http://www.fastenal.com/
your other options are McMaster Carr http://www.mcmaster.com/
or Maryland Metric http://mdmetric.com/
Old Nov 12, 2010 | 09:46 PM
98civdx's Avatar
Master Detailer
I can start my friends del sol with my other friend 95 civic key
One of my friends took a drill to them and completly rounded them off, not the brightest thing to do, but would make a pita to get off.
Old Nov 19, 2010 | 08:01 PM
NVturbo's Avatar
O.G. triple O.G.
I just replaced the two POS screws with two tamper-proof type screws. Of course, I had to drill and re-tap it according to the screw size but now I feel a little rest-asured knowing that part is taken care of.
Old Nov 19, 2010 | 08:30 PM
2k.civic.si's Avatar
just grind the heads off the screws.
Old Nov 22, 2010 | 08:47 AM
NVturbo's Avatar
O.G. triple O.G.
Yeah....then end up spending an hour to drill it out if the switch needs replacement. Bad idea.
allenhogans
Jul 26, 2017 05:20 AM
jdmjosh1
Mar 31, 2010 03:32 PM
mrchevez
Dec 7, 2009 11:00 AM
dgdarien
Oct 2, 2008 06:24 PM
