I NEED Wiring help!!!! Please!
Old May 2, 2004 | 06:06 AM
michoui16's Avatar
Default I NEED Wiring help!!!! Please!
Basic Install, I'm kinda new to audio :
I have a 1996 Honda Civic, and I want to put my Head-Unit. (Kenwood KDC-9017)
I took the old radio off (that worked just before I took it off), and figured with a multimeter and the wires diagram which wire is what. I'm pretty sure I got them right. (ACC 12V, Memory 12V, GND).
Every wires respond to the multimeter ... except the Memory (Constant) 12v.
I really dunno what it could be, I checked all the fuses and they are all good.
My question is what should I do?
p.s. the old radio worked!!!
Thanks a lot in advance!
Felix
Old May 2, 2004 | 06:47 AM
georgelb's Avatar
Default Re: I NEED Wiring help!!!! Please! (michoui16)
If all the fuses are good and the other radio worked...then you are most likely probing the wrong wire. Why not just get a wiring harness adaptor so it is plug and play?
Old May 2, 2004 | 07:12 AM
michoui16's Avatar
Default Re: I NEED Wiring help!!!! Please! (georgelb)
Well there's no other wire!
And it was the wire that was connected to the Constant 12V on the old radio.
I also thought it was a fuse, but they are all good!
Now I'm asking: is it possible that because of the anti-theft (still in), or alarm system(they took it off) that there's some protection somewhere on the circuit?
Thanks
Felix
Old May 2, 2004 | 07:43 AM
kev301's Avatar
did u check the fuse in the hood. I think its a 7.5 amp, thats probably whats out.
Old May 2, 2004 | 10:04 AM
dsmssuck's Avatar
Try this site man http://www.the12volt.com
I agree you should have just spent 10 dollars and got the harness
Old May 2, 2004 | 02:20 PM
Xsi's Avatar
Xsi
Just run another wire if you need to, newer head units draw more power anyway
Old May 4, 2004 | 04:35 AM
michoui16's Avatar
Default Re: I NEED Wiring help!!!! Please! (kev301)
Thanks, it was the fuse under the hood!
I didn't know I could get a harness for newer radio...
But then I'll need a new harness if I change radio again? Because I now have a kenwood and i'm planning on buying a new one soon. I'll need a new harness.
Where can I find that type of harness? I'll probably just rewire the original harness!
Thanks
Felix
tercelrcr
Audio / Security / Video
Oct 15, 2014 10:27 AM
eg6 type-R
Aug 7, 2012 09:49 AM
ekslammed
Dec 17, 2007 05:18 AM
