i did an install today, problems...
Old Jan 28, 2006 | 07:49 PM
mrdeadman's Avatar
They let me pick
Default i did an install today, problems...
so the sub and amp is all hooked up with an loc and everything, problem is only one channel, the left one on the amp works.. what could be the problem? this was on a ford explorer by the way.
Modified by mrdeadman at 9:00 PM 1/28/2006
Old Jan 28, 2006 | 10:17 PM
Znypar's Avatar
is this a mono amp, 2 channel, 4 channel, 5 channel? please clarify. my guess is a bad RCA cable. though. but what solution avenues have you tried?
Old Jan 29, 2006 | 09:45 AM
fcm's Avatar
fcm
Old Fart
Default Re: (Znypar)
Ditto the above.
If you switch the RCAs on the amp and the same channel is still down the problem is in the amp, if it switches to the other channel, switch the RCAs at the LOC, if the same channel is still down, its the RCAs if it switches to the other channel, switch the inputs to the LOC, again if it the same channel is down it's the LOC, if it still switches to the other channel , you have miswired the loc.
Here are the speaker wire colors for a ford....
http://www.installdr.com/Harnesses/Ford-Wiring.pdf make sure you are using the proper +/- for a left and right speaker. 94
Old Jan 29, 2006 | 09:50 AM
mrdeadman's Avatar
They let me pick
it's only a 2 channel amp. thanks, ill try that tomarrow, fcm: the wiring diagram was the one i was using, none of the wires colors matched up to the diagram so i just used the placement of the wires part to wire up the loc.
Old Jan 29, 2006 | 10:41 AM
fcm's Avatar
fcm
Old Fart
Default Re: (mrdeadman)
Which one did you use, "up to late 90s", "Ford amplified", or the "98-99 and newer"?
Which pins? 94
Old Jan 29, 2006 | 03:04 PM
mrdeadman's Avatar
They let me pick
Default Re: (fcm)
98-99 and newer. the other harness diagram doesn't even look like that and none of the colors matched on either.
SD1222
Audio / Security / Video
Aug 7, 2005 09:59 PM
hookedonvtec
13
Jul 7, 2004 06:41 AM
Liquidgsr
Jan 5, 2003 09:11 AM
integra-modder
Jan 1, 2003 02:24 PM
raene
Jul 23, 2001 01:44 PM
