how to keep my sub from bouncing around???
Old Apr 21, 2002 | 10:19 PM
zerospooon's Avatar
Default how to keep my sub from bouncing around???
i have a 10" sub in a bandpass in 98 civic hatch thats coiled all the way down on skunks2 in the back - i was just wondering whats a good way from keeping it from moving when i turn sharp or bumpy roads - lemme know thanxs
Old Apr 21, 2002 | 10:43 PM
SIRX's Avatar
Default Re: how to keep my sub from bouncing around??? (zerospooon)
Bolt it to the floor! If it's a comp car you will get deducted for it otherwise. If you want to take it out for the track, use some kind of quick release
Old Apr 22, 2002 | 11:01 AM
PupaScoopa's Avatar
Default Re: how to keep my sub from bouncing around??? (SIRX)
You can built some rails with aluminum 90-degree angle pieces from some local volume hardware store. Either build the rails to hold the sub box down or just built a frame around the box so it won't slide around (but can be lifted out with no unscrewing of anything). You can also use some 90-degree brackets.
Old Apr 22, 2002 | 03:02 PM
GSRaCeRbOI's Avatar
you can just use those 90 degree angle brackets and bolt it down.. you can find those at any hardware store...
Old Apr 23, 2002 | 04:25 PM
Thayne's Avatar
New User
Default Re: how to keep my sub from bouncing around??? (GSRaCeRbOI)
Thats what I did! Doesn't move around it all.
-Thayne
Old Apr 24, 2002 | 09:49 AM
wonny's Avatar
duct tape and some crazy glue should hold that sucker down.
Old Apr 24, 2002 | 11:31 AM
Malachi's Avatar
Default Re: how to keep my sub from bouncing around??? (wonny)
haha, epoxy will keep that stuff in place too.
Old Apr 24, 2002 | 12:56 PM
Cory's Avatar
Default Re: how to keep my sub from bouncing around??? (Malachi)
i bought some of those things you put in the corners of furniture before you move it. They fit over the corners of the box. i put the brackets down in the back where the box would sit and then screwed them into the floor and the box drops right down into the brackets
fdiddy
Audio / Security / Video
Apr 14, 2008 07:09 PM
JoeDaSoto
Jun 28, 2007 07:39 PM
jb.
May 15, 2005 06:22 PM
seppuku
Feb 5, 2004 10:25 AM
Nader_D
Jul 7, 2003 06:44 PM
