Grounding an amp
Old May 14, 2005 | 03:56 PM
jb.'s Avatar
jb.
Default Grounding an amp
THis is frustrating, first off i have a 10w7 in a sealed box powered by a 500/1. I have regrounded the amp twice, and it keeps coming loose. I am grounding it to the trunk floor of my 95 accord with a self-tapping screw that is ~3/4 of an inch long. What can i do to keep it in place or where else can i put it. I have even thought of using JB Weld, but im not sure if it conducts electricity. I am just very frustrated with this now. Also I am going to use some edead soon, and wanted to know what I should do with the ground wire when covering the trunk floor
Old May 14, 2005 | 10:46 PM
t0ekn3e's Avatar
shock tower?
Old May 14, 2005 | 11:07 PM
zumiez007's Avatar
Default Re: (t0ekn3e)
just use a ring termanal and attach it to eithor the shock tower or the large bolt which the rear seat attaches.
Old May 15, 2005 | 12:28 AM
sceg's Avatar
Default Re: (zumiez007)
after making the hole with a self-tapping screw, step up to a slightly larger screw and use a star washer
Old May 15, 2005 | 05:33 PM
parasonic's Avatar
Default Re: (sceg)
Yea, that or just find a nice big bolt, and put that bolt over an O terminal.
Old May 15, 2005 | 06:22 PM
fcm's Avatar
fcm
Old Fart
Default Re: Grounding an amp (jbkiksass69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbkiksass69 &raquo;</TD></TR><TR><TD CLASS="quote">THis is frustrating, first off i have a 10w7 in a sealed box powered by a 500/1. I have regrounded the amp twice, and it keeps coming loose. I am grounding it to the trunk floor of my 95 accord with a self-tapping screw that is ~3/4 of an inch long. What can i do to keep it in place or where else can i put it. I have even thought of using JB Weld, but im not sure if it conducts electricity. I am just very frustrated with this now. Also I am going to use some edead soon, and wanted to know what I should do with the ground wire when covering the trunk floor</TD></TR></TABLE>There are lots of bolts going into the floorpan under the rear seat, seat belt bolts work great, the 10mm bolt that holds the back bottom of the rear seat in, also works good, a bolt going into a nut that is welded to the floorpan, that you can torque down to 25ftlb or more is a lot better then a selftaper screwed into a 26/24 ga pc. of sheetmetal that you can torque down to maybe 1 or 2 ftlb before it strips out. 94
ALDJ253
Mar 11, 2014 03:41 PM
ALDJ253
Mar 10, 2014 01:53 PM
thatasiankidtony
Nov 23, 2006 10:09 AM
Quetzolcotl
Feb 11, 2004 07:32 PM
elwood
Apr 14, 2003 12:31 AM
