How do you run power wire from the battery in '98 Accord Coupe?
Old 07-11-2004, 10:48 AM
99IntegraGS's Avatar
Default How do you run power wire from the battery in '98 Accord Coupe?
I've found one unused hole in the firewall, but I can't seem to find it on the interior side. I tried removing the glove compartment, but the four visible screws aren't enough to free it from the dash.
Anyone have any advice?
Thanks,
JD
Old 07-11-2004, 11:46 AM
Default Re: How do you run power wire from the battery in '98 Accord Coupe? (99IntegraGS)
Got the answer here...
https://honda-tech.com/zerothread?id=922268
Old 07-11-2004, 12:33 PM
fcm
Old Fart
fcm's Avatar
Removing the glove box isn't going to help much as the heater motor and duct are in the way, it's a tight fit between heater motor housing and firewall,about 1", but you can poke a snake or hanger down the hole from the engine bay,it will be behind the soundmat at about were the bottom mount for the heater duct is,[works best with 2 people one poking one feeling] cut xslit in soundmat,feed wire down from hole to xslit, pull through. 94
Old 07-11-2004, 06:35 PM
Default Re: How do you run power wire from the battery in '98 Accord Coupe? (fcm)
I ended up using a hole closer to the driver's side... than ran it across behind the dash and down the passenger side of the car.
Long day, many hours spent on that stereo install this weekend. Not a bad system for my daughter's car, all made up of hand-me-down parts I gave her except for the Kenwood headunit which she bought a couple of years ago.
1998 Honda Accord EX Coupe V6
Kenwood KDC-MP522 CD/MP3 Receiver
Kenwood KAC-849 4-channel Amp
Kenwood KAC-819 Mono Amp
Kenwood KFC-1687 6½" 3-way speakers
Kenwood KFC-6959ie 6"x9" 2-way speakers
JL Audio CB110-W0 Bandpass Subwoofer Enclosure
Old 07-12-2004, 08:34 AM
fcm
Old Fart
fcm's Avatar
What ever works. 94
AHHthatsJDMyo
04-08-2009 08:02 AM
tyronne1126
Lighting
08-17-2008 07:03 PM
boostlesseg
06-06-2008 12:08 PM
hob4G
06-24-2004 07:13 AM
legion1011
10-16-2002 08:06 PM
Quick Reply: How do you run power wire from the battery in '98 Accord Coupe?
