HOW do i wire a switch ?
I cannot figure out how to wire a switch , it keeps burning the wires..
Im just using this as an example...
Lets say i wanted to wire headlight flashers up to a switch, Where does the power, Ground, and the wire to the flashers go? I cant figure it out
If you wanted to wire up a heavy duty circuit like headlights, you'd also need a relay.
If your wires are burning, you're either shorting them to ground or using way too small gauge of wire. USE A FUSE.
epicbeats
Jul 29, 2009 12:59 PM
aser1z
Dec 7, 2007 09:13 PM
integraXTC
Aug 4, 2005 08:27 AM
