how do i convert....
Old Oct 20, 2004 | 07:25 PM
89hbcivicguy's Avatar
Default how do i convert....
how do i convert 2.0cubic feet into dimensions?....
and 1.5 cubic feet into dimensions?
Old Oct 20, 2004 | 07:36 PM
t0p_sh0tta's Avatar
Default Re: how do i convert.... (89hbcivicguy)
What are the dimentions of the space that you have to work with?
Length X Width X Height = _______ / 1728 = Enclosure size in ft^3
Old Oct 20, 2004 | 08:57 PM
D'Ecosse's Avatar
Default Re: how do i convert.... (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">What are the dimentions of the space that you have to work with?
Length X Width X Height = _______ / 1728 = Enclosure size in ft^3</TD></TR></TABLE>
At least when the length, width & height are measured in inches.
To give you a general idea, 1 cubic foot is a box that measures 12" x 12" x 12" =1728 in^3 or 1.0 cu ft (or ft^3)
Or 1.5 cu ft is 18" x 12" x 12"
& 2.0 cu ft is 24" x 12" x 12"
You can manipulate each of the dimensions as required to meet your number:
If you know 2 dimensions, you can work out the other
Example:
You want 2.0 cu ft and you have 20" wide & 8" deep to work with in your desired space: you need to know how high ("h") the box will be for 2.0 cu ft.
The thing to remember however is that the volume is that of the inside dimensions of the box, so you need to account for double the thickness of your material in the dimensions.
i.e if using 3/4" MDF, subtract 1.5" from each length as your raw side dimensions.
So that now leaves 18.5" (20"-1.5") x 6.5" (8"-1.5") as your inside dimensions
2.0 cu ft = 1728 x 2.0 = 3456
3456 = 18.5 x 6.5 x "h"
=&gt; h = 3456/ (18.5 x6.5)
=&gt; h = 3456/120.25
=&gt; h = 28.74 " ~= 28-3/4" + 1.5" = 30-1/4"
So a box approx. 30" x 20" x 8" (external dimensions) made of 3/4" MDF would net ~ 2.0cu ft internal volume.
The only other spoiler here is that is the <U>gross</U> volume - you need to subtract the displacement of the speaker(s) to give you net (or vice-versa, add it to the 2.0 before you do the calculation to find your actual dimensions)
Modified by D'Ecosse at 10:10 PM 10/20/2004
Modified by D'Ecosse at 10:13 PM 10/20/2004
jthm
Jan 16, 2007 06:40 AM
deeweezy
Audio / Security / Video
13
Oct 8, 2003 05:37 PM
ODX
Nov 27, 2001 04:37 AM
