Security
Old Oct 17, 2004 | 04:46 AM
ecmo1's Avatar
Default Security
I'm not sure where I should post this.
My question is, how much integrity does a door popper have. I was planning to shave my door handles and install door poppers, but I heard that it's easy to find the frequency of the keyless entry. Thank you.
Old Oct 17, 2004 | 08:36 AM
fcm's Avatar
fcm
Old Fart
Default Re: Security (ecmo1)
Use the EXT outputs of a good alarm,[ codehopping antiscan] to trigger the poppers. 94
Old Oct 18, 2004 | 12:40 AM
ecmo1's Avatar
Default Re: Security (fcm)
I was about to buy a standard door popper kit for 300. Since you brought that up, where can I find that "EXT Scanner" at? My brain scrambled when you brought that up, unless you're just talking out of your ***. (no offense)
Old Oct 18, 2004 | 10:54 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ecmo1 &raquo;</TD></TR><TR><TD CLASS="quote">I was about to buy a standard door popper kit for 300. Since you brought that up, where can I find that "EXT Scanner" at? My brain scrambled when you brought that up, unless you're just talking out of your ***. (no offense) </TD></TR></TABLE>Its not an "EXT Scanner" all good alarms have anti code grabbing and anti scan technology, so if you get an alarm,[a good one] and use two or three of its EXTs, [like trunk release] one for the drivers door popper, one for pass. side and one for both, then all you need is the poppers themselfs and not the kit ,that comes with the"keyless entry" that is easy to find the frequency for 94
Old Oct 19, 2004 | 01:41 AM
ecmo1's Avatar
Would you mind giving me an example of a brand that's really good. Also, so are you saying to buy the kit and alarm and I should be good to go. You were specifcally talking about the alarm that had that special feature right? Thanks.
Old Oct 19, 2004 | 07:10 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ecmo1 &raquo;</TD></TR><TR><TD CLASS="quote">Would you mind giving me an example of a brand that's really good. Also, so are you saying to buy the kit and alarm and I should be good to go. You were specifcally talking about the alarm that had that special feature right? Thanks. </TD></TR></TABLE> Any brand name alarm will work, if you can find an Alpine SEC 150, you can't do better .
What you need in the alarm is no less then 2 EXT. outputs, the rest is up to you .
Compustar also make very good alarms and alarm/starters, both 1 way and 2 way pager systems and they have at least 2 EXT outputs.
When you say"kit", as long as the "kit" does not come with a R/F mod. [ a remote control] you have that with the alarm, all you need are the door poppers and hardwear to mount them ,[ unless it comes with a relay pack,you will need at least two relays. 94
Old Oct 20, 2004 | 10:49 PM
ecmo1's Avatar
Ahh, I understand now. Just get the poppers themselves and not the remote. Buy the pricey alarm and have it's 2 ext connected w/ the poppers so, I'd probably have to buy 2 sets. Thanks for the input.
tundra2000
Jul 13, 2011 05:21 AM
datssoled
Sep 28, 2006 07:30 PM
dem0nk1d
Audio / Security / Video
15
Sep 24, 2006 07:53 AM
AMECustom
Nov 26, 2005 07:05 PM
devilpuppy
May 17, 2004 07:02 PM
