How do I add an Audio Input?
Old Apr 21, 2002 | 08:10 PM
JustChou's Avatar
Default How do I add an Audio Input?
Hey guys~
I've been working on adding a video screen and PSX in my car, and I've decided that I want the audio output of the PSX to go to the car, instead of the pint-sized speakers which are integrated in the video screen. However, I don't have an aftermarket reciever. Is there any way I can do this?
Thanks.
Old Apr 21, 2002 | 08:46 PM
Louie B.'s Avatar
Default Re: How do I add an Audio Input? (JustChou)
go to a clarion dealer and get an FMC100 (I think that's what the number is) It will take an RCA audio input and turn it into an fm signal so you can just tune your stereo in.
Old Apr 24, 2002 | 11:47 AM
PupaScoopa's Avatar
Default Re: How do I add an Audio Input? (thumpu77)
That's called an RF Modulator. You can also pick them up from Parts Express. Another idea is a Master Volume Control. This takes several inputs, lets you switch and adjust volume, then sends a straight or mixed output to your amps (if you run amps). Otherwise the modulator will work. Be warned that your FM reception might go all to hell running a modulator while it's powered on (you'll want to power it off if you're not using the PSX)
wjwyatt
Oct 8, 2018 11:05 AM
Nighthawk R18
Honda Civic (2006 - 2015)
Aug 23, 2009 10:45 AM
Civic92Turbo
Audio / Security / Video
Aug 5, 2008 05:10 AM
bassisliffe
Nov 3, 2004 05:46 PM
Goldfingiz
14
Aug 13, 2003 08:54 PM
