how do I..??
Old Jul 20, 2002 | 09:37 AM
rasta420's Avatar
Default how do I..??
simple question..
i have a CD player, but without having to buy a separate tape player, how can i listen to tapes in my car? is there a way to hook up a separate...something...to listen to tapes?
thanks
Old Jul 20, 2002 | 10:14 AM
GSteg's Avatar
Default Re: how do I..?? (rasta420)
wait..you don't want to buy a seperate player to play your tapes, but you want to find out if there is any seperate tape players that will play your tapes without getting a seperate tape player? i'm confused...
Old Jul 20, 2002 | 10:38 AM
rasta420's Avatar
Default Re: how do I..?? (GSteg)
yea that was kinda confusing..i meant, i dont want to add another head unit that plays just tapes to my dash...maybe a smaller, cheaper alternative way?
HELP!
Old Jul 20, 2002 | 10:51 AM
GSteg's Avatar
depending on what headunit u have, some alpines have the AUX plug which you can plug in other sources like walkman too.
Old Jul 20, 2002 | 10:53 AM
sammysnakes's Avatar
Default Re: how do I..?? (Teken)
It's called a walkmen...
that would be walkman
Old Jul 20, 2002 | 11:42 AM
GSRaCeRbOI's Avatar
if your head unit has an input (typically like a head phone jack or an input plug/adapter that has RCA plugs) you can hook up a walkman that way..
another way to do it is.. theres this device called a CD feeder or sum $hit like that.. its about $30 at radio shack or tower records or Circuit city or other electronic/music stores..
it is intended to hook up a Discman and it will output the sound through an unused FM stereo channel/frequency.. but I'm sure you can use that device to get output from a walkman.. and feed the signal thru an unused frequency..
how it works is like this.. you plug in the device to ur cigg lighter so that it powers itself and also it has power outputs (and comes w/ a bunch of adapter plugs for difference diskmans) find the one that fits your walkman (tape) and make sure u get the voltage and polarity set correctly..
now lets say frequency 88.90 (im just pickin one out randomly) in your area is NOT used/NOT a radio station.. so you dial in the sound feeder device (hooked up to your walkman and cigg plug already) to 88.90.. now you tune your car stereo's FM tuner to 88.90.. and press play on your tape deck.. and that thing should make an FM signal to output the sound on your walkman.. and your Head unit should pick up that signal and the sound from your walkman comes out the Sound Feeder should be picked up from your tuner and outputed to your speakers..
let me see if I can find this device on the web so u kno wtf I'm talkin about.. this is the cheapest way I can think of unless ur deck has AUX inputs.. this is for pricepoint, not sound quality... it should suffice though..
Lolz BTW I don't even own tapes anymore.. I replaced my perfectly working Alpine tape deck w/ a CD unit and mp3 changer.. Lolz
edit: here u go bro.. this is what I was talkin about..
http://www.reviewboard.com/Section/Car-Audio/sfwcpa
hmm the one shown here is operated by AA battery.. but I know for a fact there is one that plugs into the cigg lighter so u dont have to keep buying batteries.. my friend has it.. I think its like the sound feeder 300 or sumthing...
[Modified by GSRaCeRbOI, 12:50 PM 7/20/2002]
Old Jul 20, 2002 | 02:01 PM
rasta420's Avatar
hmm maybe you mean "a walkman"
thanks for the help buddy
Old Jul 20, 2002 | 02:04 PM
rasta420's Avatar
Default Re: how do I..?? (GSRaCeRbOI)
wow thanks for the help...i have the kenwood mp919 head unit, im not sure if it has any AUX inputs, but i know it has front/rear/non-fading outputs...
ill go ahead and try the CD feeder idea
thanks again
EDIT: that link isnt working!
[Modified by rasta420, 11:05 PM 7/20/2002]
Old Jul 20, 2002 | 02:37 PM
GSRaCeRbOI's Avatar
i can't link the picture.. but the link should work (i just clicked on it)
the picture I was trying to link was from the above link.. it basically tells you what the product does and has a pic of it.. dunno y the link to the pic wouldn't work..
Old Jul 21, 2002 | 07:12 AM
LillDragun's Avatar
i'm gonna tell you know that that thing really sux. i had it for my mom's car cause hers was only tape player and i wanted to play cds......well i hooked it up to my discman and since it uses a radio channel it has alot of static. and it adds the loud hiss to the music. really a terrible investment of $25.
Old Jul 21, 2002 | 09:01 AM
GSRaCeRbOI's Avatar
Default Re: how do I..?? (LillDragun)
well he's trying to listen to tapes so the output quality isn't all that great either.. but thats wierd because my friend used it in his eclipse for awhile and although it didn't come close to my Alpine cd player.. it was decent for the $25 he spent on it.. there wasn't hiss and stuff...
Old Jul 21, 2002 | 02:33 PM
o_Rage_o's Avatar
yea i've seen the units in action as well..no hiss, not perfect, but it still gave good clean signal
-Rage
Old Jul 21, 2002 | 08:07 PM
LillDragun's Avatar
Default Re: how do I..?? (o_Rage_o)
hmmm maybe mine was a defective one.....cause i toggle'd the fine tune and the maine tuning dial for like 20-30 min and then i gave up. hehe
Old Jul 21, 2002 | 08:21 PM
rasta420's Avatar
where did you guys get them from? what are they called?
thanks for all the helpful replies
Old Jul 22, 2002 | 06:34 PM
rasta420's Avatar
anyone?
Old Jul 22, 2002 | 06:45 PM
GSRaCeRbOI's Avatar
the link didn't work?
its called "sound feeder" then followed by a number.. the higher the number the "supposed better" it is or whatever Lolz..
they should be under $30.. like around $25... and stores like Circuit city, Sam Goody (the music/cd store), Tower Records (music/cd store), Best Buy, etc.. should carry them...
it worked fine in my friends eclipse (fixed/fully extended antenna)... plus if it doesn't work well for you for whatever reason you can always return it so its worth a try...
Old Jul 22, 2002 | 06:55 PM
audioroach's Avatar
hey rasta...your 919 deck may be able to use the kenwood aux input plug...i can't find my 'wood lit...what it does...it plugs into the cd changer input and toogles open the audio input and its has female rca plugs on the end...when you select source it will open it up...now your deck would have to have changer controls that are not being used.......Same thing goes for you Pioneer and alpine people as well...
Hope this helped
TSX TEX
Acura TSX
Feb 1, 2008 06:09 AM
Mitcher
Audio / Security / Video
Jun 8, 2007 09:26 AM
naoandlata
14
Aug 3, 2005 12:45 PM
coupedup
Dec 7, 2004 04:34 PM
whoobeedoobee
Jul 21, 2003 06:05 PM
