how to connect the door trigger properly
Old Oct 16, 2006 | 08:40 AM
konidude's Avatar
Default how to connect the door trigger properly
As it says in the electrical layout, you need to connect the kick panel green/red wire on the alarm door trigger input
the problem is that my green/red wire send +12v while the doors are closed and the alarm required a negative input or a positive input (while doors are open)
how did you guys go around this
for a while i've put a relay to converse voltage input but it kills the battery if you dont use your car for a couple of days
thanks for your advises
Old Oct 16, 2006 | 08:46 AM
B18C_EJ8's Avatar
Doesn't your alarm have a pos. trigger? What kind of alarm?
If not, yes you can use a relay to make the positive trigger into a negative... And no, it will not kill your battery... It's only activated when the door is open.
Old Oct 16, 2006 | 08:52 AM
konidude's Avatar
it's a viper,
as i was saying the signal is +12v while the door are closed, the alarm will take the +12V while doors are opened
so i'm wondering if i'm using the proper green / red wire
Old Oct 16, 2006 | 09:00 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (konidude)
First did you test the wire with a dvm? I bet you didn't because that wire rest at 12volts. And when you open the door it becomes chassie ground. There are 4 wires with the same color. You need to test all the wire before just hooking them up.
Old Oct 16, 2006 | 04:33 PM
AirWaveGT's Avatar
Default Re: (wrx-killer-Sti eater)
you need to test the wire when the doors are closed and then with a door open. if the doorpin is (-) then it will test 12v with the doors closed and ground (or show 0v) with a door open. if its (+) then it will test 0v with the doors closed and 12v with a door open.
Old Oct 16, 2006 | 06:51 PM
fcm's Avatar
fcm
Old Fart
Default Re: (AirWaveGT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AirWaveGT &raquo;</TD></TR><TR><TD CLASS="quote">you need to test the wire when the doors are closed and then with a door open. if the doorpin is (-) then it will test 12v with the doors closed and ground (or show 0v) with a door open. if its (+) then it will test 0v with the doors closed and 12v with a door open.</TD></TR></TABLE> We have a winner, and it only took 5 posts
If it's a Honda/Acura it has neg.(-) door triggers, if you "lift" the ground, [open pin switch by closing door] on a circuit with a load, [dome light] when you meter the ground lead you read the 12V+ on the other side of the load, [light bulb filament] 94
Old Oct 16, 2006 | 09:34 PM
Default Re: (fcm)
heyyyyyy, I won first...wtf ,,,lol. That was my shyt reworded lol. ok ok next time I'll be more technical
Old Oct 17, 2006 | 09:08 AM
konidude's Avatar
thanks guys,
but while doors are closed, is the pos 12v will hurt the alarm, since it's supposed to pick up negative??
Old Oct 17, 2006 | 09:11 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">is the pos 12v will hurt the alarm</TD></TR></TABLE>
No. It will not hurt anything.
nrh24
Honda CR-V & Element
May 14, 2017 09:15 PM
EJ8 GSR-T
Audio / Security / Video
11
Apr 29, 2007 03:35 PM
djbrandonr
Jul 22, 2006 01:25 PM
Dub C
Mar 17, 2006 10:33 AM
willyboyK20
Apr 18, 2002 04:51 AM
