Hey! Do you have a FP Kill switch?
Old May 4, 2004 | 12:11 PM
what the...'s Avatar
Default Hey! Do you have a FP Kill switch?
so I've been reading a few of the archived threads on this subject, and I am thinking it's not too difficult for me to understand and do correctly. As far as I understand, all I need to do is break the power to the FP, and use a switch that matches the DC amp rating plus 20%, or just use a switch and relay. I have two questions:
1. Has ANYONE on this board used a switch w/o a relay for an extended period of time and had NO problems with it? people complain that w/o the relay, the switch eventually needs to be replaced.
2. On this thread in the twelth post of the first page, Happyman says that if you have VAFC, you can just take the unit with you and it will disable ECU, rendering the vehicle immobile. Is there any truth to this? If I pull the display out of the car, will I have to initialize and reset it everytime I plug it back in?
Thanks for any help you guys have. I'm kinda hoping the VAFC thing will work.
Zack - who hears his car alarm in his sleep.
Old May 4, 2004 | 02:15 PM
audioroach's Avatar
Default Re: Hey! Do you have a FP Kill switch? (what the...)
Always use a relay...no exceptions!..the relay will outlast
your car before it fails. Anyway the heavy duty switch thats needed is
so friggin' huge that it defeats the purpose.
I have a relay based immobilizer that diasbles the ignition circuit
completely. When triggered it simulates engine failure.
On the plus side..the switch that triggers it can be easily hidden.
( One can even use existing switches to activate it).
Hope this helps.
Old May 4, 2004 | 04:20 PM
Default Re: Hey! Do you have a FP Kill switch? (audioroach)
did you get the switch and relay at radio shack, or what? Just wondering weher I can get the parts. Know of any good DIY's or something with apicture/diagram? Thanks for your input
Old May 4, 2004 | 06:50 PM
luciferi's Avatar
If you want to kill the pump, kill the power to the pgm-fi main relay. This way it will also shut the injectors down so they don't get cranked dry.
Old May 4, 2004 | 06:55 PM
Default Re: Hey! Do you have a FP Kill switch? (luciferi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luciferi &raquo;</TD></TR><TR><TD CLASS="quote">If you want to kill the pump, kill the power to the pgm-fi main relay. This way it will also shut the injectors down so they don't get cranked dry.</TD></TR></TABLE>
can I do this with one switch? or do I need to have a switch for the FP and one for PGM-FI? If I put one onthe PGM-FI will that solve the problem entirely?
Just to bump, can anyone corroborate this VAFC info?
Old May 4, 2004 | 07:12 PM
audioroach's Avatar
Hmm..lets see if you disable the cars ignition circuit,the fuel
pump or related items wont function...basically the car will crank
but not fire. THe injectors should not run dry. Try it...its fun.
eazy64
Oct 17, 2010 09:09 PM
thundernoodle
Audio / Security / Video
15
Aug 6, 2010 06:05 AM
eL_cArLos
Feb 20, 2008 06:19 PM
JLEK
May 10, 2007 10:40 PM
RCautoworks
Dec 30, 2002 01:51 PM
