HELP: noise at idle
Old Mar 28, 2006 | 08:18 PM
bOOsTiNSoHcVtEc's Avatar
Default HELP: noise at idle
Hoping I could get some help before I go back to the person that installed it for me tomorrow. I just got a 4 channel amp and components put in. Well we first had a problem where I was getting a whining noise that increased as the revs went up. That was eliminated using a ground loop isolator. Now, I still have this noise at idle, like a humming noise. It goes away or gets really low as the revs get higher. Now ive been reading and searching.. most threads state that it could be a problem from the rcas being to close to the power cable or a bad ground coming from either the amp or head unit. I guess I will suggest that to my installer tomorrow but I was wondering is it okay to add another ground that was thicker in gauge to the headunit just to see what happens? Also are there any other suggestions or solutions that I could try? Thanks
Old Mar 28, 2006 | 08:52 PM
silentblackhat's Avatar
Default Re: HELP: noise at idle (bOOsTiNSoHcVtEc)
what is the amp grounded on? you may not need the device to isolate the ground loop if you relocate the ground or make it a clean ground
who installed your amp?
Old Mar 28, 2006 | 09:38 PM
Default Re: HELP: noise at idle (silentblackhat)
to the bottom of the trunk underneath the carpet. my friend who works in the best buy install bay did the installation
Old Mar 29, 2006 | 12:55 AM
XaznKewLguyX's Avatar
oops just read the full post
DcLs
Audio / Security / Video
12
Nov 22, 2008 05:58 AM
Crank
11
Nov 30, 2005 01:04 AM
scrambledeg
10
Dec 9, 2003 07:12 PM
94Accord2c
Nov 21, 2003 07:03 AM
TurboTeG4
Nov 2, 2003 05:59 PM
