Help: No Sound from Headunit
Old Apr 9, 2005 | 10:55 PM
moonchie's Avatar
Default Help: No Sound from Headunit
Ok so today I was trying to install an amp, and was messing with some of the wires in the back of my headunit, as well as the fuses for the wirekit, and fuses for my car (IE:radio, cigarette lighter, and from teh fusebox in engine bay)
Now I put everything back, and deck turns on fine, but there is no sound coming out of any of my speakers. Any Idea on what may have happened??
Old Apr 10, 2005 | 12:26 AM
idriveadelsol7's Avatar
Default Re: Help: No Sound from Headunit (moonchie)
if the head unit works and the amplifier works... then it isn't the power/ground or remote wires. maybe the RCA or speaker wires is/are loose? check the amplifier settings
Old Apr 10, 2005 | 05:57 AM
moonchie's Avatar
Default Re: Help: No Sound from Headunit (unrefined7)
head unit works but the amp still doesn't work...
Old Apr 10, 2005 | 07:33 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
check
constant 12v or power,make sure you have a good connection, there's a GOOD fuse in the fuse holder, and there are no places the power wire is knicked.
remote turn on wire...should read at least a few volts with a volt meter, or will light up a test light.
make sure ground connection is solid...
if none of that seems to be the problem...you have a bigger problem than you think...possibly bad output on radio...
Old Apr 10, 2005 | 07:29 PM
SIMATIC's Avatar
Default Re: Help: No Sound from Headunit (DAantagonist)
well my head pioneer head unit just shut off on me 1 day, it worked fine just no sound from speakers...it was the amp in the head unit that blew out,
just a thoughttt man
Old Apr 11, 2005 | 06:27 PM
Dougs96SI's Avatar
Default Re: Help: No Sound from Headunit (SIMATIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIMATIC &raquo;</TD></TR><TR><TD CLASS="quote">the amp in the head unit that blew out</TD></TR></TABLE>
That was my first thought.
If not that go back and check the speaker connections in the wiring harness.
Keangdawizes
Audio / Security / Video
Jun 4, 2008 08:09 AM
ppfalcon
Sep 7, 2005 08:25 AM
byronl
Jun 22, 2005 08:16 AM
anarchyfox
10
Apr 26, 2004 07:14 PM
Bklyn TSi
Nov 6, 2001 11:11 AM
