help me with this setup
Old May 29, 2006 | 07:35 PM
jdmsoljah's Avatar
Default help me with this setup
well all i need is help with or answer myt question the problem is that where do i connect the cap too ok here the setup 4 gauge wire 12 from the battery then to a 40amp fuse in a holder then 18 feet to a distributor block 1 4 gauge in and two 8 gauge out connected to the amp so where do i connect the capacitor to and do i have to cut line well can someone draw me a picture or is there a web site thanks peeps..
Old May 29, 2006 | 07:46 PM
02 accord's Avatar
Default Re: help me with this setup (jdmsoljah)
The cap would go on the power and ground wires at most 18 inches from the amp. So mount the amp and the cap next to each other. Then, run your two 8 gauge power wires from the amp to the cap. Do likewise with the single ground wire. Then, run the 2 power wires from the cap to the distribution block, and the ground wire, also from the cap, to the chassis.
Old May 30, 2006 | 06:41 PM
jdmsoljah's Avatar
but what 1f 1 am runnnn two amps help....
Modified by jdmsoljah at 9:23 PM 5/30/2006
Old May 31, 2006 | 07:46 AM
fcm's Avatar
fcm
Old Fart
Default Re: (jdmsoljah)
More info......
1- What amps do you have, [make and model]?
2- What are the amps running? 94
Old May 31, 2006 | 08:00 AM
02 accord's Avatar
Either split the 8 gauge wires from the capacitor, or use the cap on only one amp.
Old May 31, 2006 | 06:41 PM
jdmsoljah's Avatar
runnin a 250by 2 kicker kx amp and a xtreme amp 300by 2 amp 300 by two runnin my higha and the 250 by 2 runnin my sub
Old May 31, 2006 | 07:53 PM
LSRracing95's Avatar
well. generally, the power cap will be placed "on" the subwoofer amplifer.
with your setup.. i see no need for a power capacitor to begin with.
Old Jun 1, 2006 | 11:41 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsoljah &raquo;</TD></TR><TR><TD CLASS="quote">runnin a 250by 2 kicker kx amp and a xtreme amp 300by 2 amp 300 by two runnin my higha and the 250 by 2 runnin my sub</TD></TR></TABLE> Need model numbers......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSRracing95 &raquo;</TD></TR><TR><TD CLASS="quote">well. generally, the power cap will be placed "on" the subwoofer amplifer.
with your setup.. i see no need for a power capacitor to begin with.</TD></TR></TABLE> Ditto the above. 94
Old Jun 4, 2006 | 08:10 PM
jdmsoljah's Avatar
got it for free
tempsohc
Audio / Security / Video
Jul 31, 2013 09:30 PM
aznjay510
Oct 6, 2009 05:44 AM
patrick4588
26
Jun 17, 2008 08:10 AM
LuckyHonda839
Mar 5, 2008 04:01 AM
R Thizzel
17
Nov 22, 2004 05:48 PM
