Installation help with my Cap
Old Oct 30, 2004 | 03:19 PM
R Thizzel's Avatar
Default Installation help with my Cap
i picked up this RF cap from my friend a while back and its been laying in my room ever since. i got bored today and i charged it up. now all i need to do is hook it up. i have a 1400 watt amp hooked up to 2 digital audio subs. can somebody help me with this
Old Oct 30, 2004 | 03:41 PM
R Thizzel's Avatar
Default Re: Installation help with my Cap (R Thizzel)
no one knows how to do this?
Old Oct 30, 2004 | 03:50 PM
nsxxtreme's Avatar
Hook it in parallel with the sub amplifier power wires, keeping the wires as short as possible.
Old Oct 30, 2004 | 03:53 PM
R Thizzel's Avatar
Default Re: Installation help with my Cap (nsxxtreme)
theres only one power wire
maybe im missing the concept
Old Oct 30, 2004 | 06:27 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R Thizzel &raquo;</TD></TR><TR><TD CLASS="quote">theres only one power wire
maybe im missing the concept</TD></TR></TABLE> Power wire from batt. to cap pos.[+] from cap pos.[+] to amps pos.[+] term as close as possible, ground the cap at the same place that the amp is grounded at. BTW discharge the cap first, remove the fuse on the power wire, wire the cap, then charge the cap, reinstall fuse, good to go. 94
Old Oct 30, 2004 | 06:47 PM
nsxxtreme's Avatar
Actually you want the negative to go directly to the amplifier don't run it to where the amplifier is grounded. I think this is what you meant to say. You want both wire as short as possible. Ground is still a power wire current flows throught it. So as already mentioned connect the + on the cap to the + on the amp. Connect the - on the cap to the - on the amp.
Remember current must complete a loop it must start and stop in the same place. If you have a short + and a long - the current still has to flow back through the long - wire. Which is bad, there are parasitics associated with that.
Modified by nsxxtreme at 8:37 PM 10/30/2004
Old Nov 5, 2004 | 10:47 AM
R Thizzel's Avatar
Default Re: Installation help with my Cap (fcm)
how do u charge the cap back up after uve hooked it up to the power wire
Old Nov 5, 2004 | 02:54 PM
nsxxtreme's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R Thizzel &raquo;</TD></TR><TR><TD CLASS="quote">how do u charge the cap back up after uve hooked it up to the power wire</TD></TR></TABLE>
You don't need to once its hooked up to a constant power source it stays charged.
Old Nov 9, 2004 | 08:37 AM
R Thizzel's Avatar
so it needs to be grounded to a different place than the amp is?
Old Nov 9, 2004 | 11:15 AM
PM-Performance's Avatar
no . i ran the ground to my cap and then from the cap to the amp. works great.
Old Nov 9, 2004 | 07:19 PM
fcm's Avatar
fcm
Old Fart
Default Re: (nsxxtreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">Actually you want the negative to go directly to the amplifier don't run it to where the amplifier is grounded. I think this is what you meant to say. You want both wire as short as possible. Ground is still a power wire current flows throught it. So as already mentioned connect the + on the cap to the + on the amp. Connect the - on the cap to the - on the amp.
Modified by nsxxtreme at 8:37 PM 10/30/2004</TD></TR></TABLE>No, I ment ground the cap at the same place you ground the amp, we have found that it works better that way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R Thizzel &raquo;</TD></TR><TR><TD CLASS="quote">so it needs to be grounded to a different place than the amp is?</TD></TR></TABLE> NO. You can run the ground to the cap and then to the amp, just like the power, or, [ and I think its better] ground it at the same place as the amp is grounded.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R Thizzel &raquo;</TD></TR><TR><TD CLASS="quote">how do u charge the cap back up after uve hooked it up to the power wire</TD></TR></TABLE> The cap should be discharged when you do the hook ups, and charge it after it's all wired up, just leave the fuse on the power wire by the batt. out, then to charge the cap just wire a 12v lightbulb in series in place of the fuse, it will come on bright and then dim out, when it's out, cap is charged. 94
Old Nov 10, 2004 | 05:35 AM
jb.'s Avatar
jb.
Default Re: (fcm)
so then you can hook the ground wire coming from the amp to the terminal on the cap? then ground the cap to the car?
Old Nov 10, 2004 | 06:21 AM
Default Re: (jbkiksass69)
yes
Old Nov 10, 2004 | 04:54 PM
fcm's Avatar
fcm
Old Fart
Default Re: (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">yes</TD></TR></TABLE>Ditto that 94
Old Nov 22, 2004 | 02:54 PM
R Thizzel's Avatar
Default Re: (fcm)
alright i can do that now how the hell do u do the light bulb thing? sorry im an idiot
Old Nov 22, 2004 | 04:03 PM
fcm's Avatar
fcm
Old Fart
Default Re: (R Thizzel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R Thizzel &raquo;</TD></TR><TR><TD CLASS="quote">alright i can do that now how the hell do u do the light bulb thing? sorry im an idiot</TD></TR></TABLE>Using any 12 volt lightbulb. [ I have evan removed and used the domelight bulb] all you have to do is put the bulb in series in the power wire, I do it at the fuseholder, [with the fuse out] touch the pos. (+) of the bulb, [ the pin on the bottom of the bulb] to the batt. side of the fuseholder, and touch the neg. (-) part of bulb, [the ground or side of bulb] to the wire going to the amps/cap, when you do this the bulb will light up bright, then slowly get dimmer till it gos out, or almost out, cap is charged.
PS Do not hold bulb by the glass part, it will get HOT, also its only 12volts, you can NOT get a shock. 94
Old Nov 22, 2004 | 05:18 PM
R Thizzel's Avatar
Default Re: (fcm)
alright well my amp is already charged up, (sombitch), how do i discharge it?
Old Nov 22, 2004 | 05:48 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R Thizzel &raquo;</TD></TR><TR><TD CLASS="quote">alright well my amp is already charged up, (sombitch), how do i discharge it?</TD></TR></TABLE> You don't need to discharge an amp. if you are adding the cap to the system, just disconnect the batt. or remove the fuse on the power wire to the amp, [ the one close to the batt.] then install the cap, [as close to the amp as you can] after every thing is wired then do the lightbulb thing. 94
Blahblah718293
Audio / Security / Video
Mar 25, 2008 07:15 AM
thatasiankidtony
11
Apr 5, 2007 01:53 PM
ChronicFrogs2004
10
Aug 2, 2004 02:53 PM
ackerjack
Jul 24, 2004 07:02 AM
GooD moToRs
Dec 27, 2003 08:12 PM
