help with LED
Old Sep 23, 2004 | 04:02 PM
.ShawnD.'s Avatar
Default help with LED
i have this LED and it has3 wires red yellow and black
RED: 12v constant
YELLOW: 12v ignition grounded when engine is off
BLACK: reg. groun
where would be a good place to hook up the yellow wire, if i just hook up the red and black the LED would stay on all the time .. so i wanna do it right. thanks
Old Sep 23, 2004 | 04:12 PM
B18C_EJ8's Avatar
Yellow needs to go to a source of constant 12v. You can get this at the battery, fuse box, or ignition harness...
Old Sep 23, 2004 | 04:28 PM
.ShawnD.'s Avatar
well the yellow wire is power when the cars off. and im not fimilar were to hook it up with somthing that has power with the car off.. thats my question .. what could i hook it up to?
Old Sep 23, 2004 | 04:49 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> Yellow needs to go to a source of constant 12v. You can get this at the battery, fuse box, or ignition harness... </TD></TR></TABLE>
Old Sep 23, 2004 | 04:51 PM
jdmotorsports's Avatar
Default Re: help with LED (.:s h a w n D:.)
yellow need to go to ground. you could put a switch in so it'll turn on when you use the switch. other then that you can rig up a relay to switch ground on when power goes off.
Old Sep 23, 2004 | 05:24 PM
ben gee's Avatar
Default Re: help with LED (jdmotorsports)
if you have an alarm you can hook up it to, negative when armed output if it is a DEI alarm orange wireusually 1st pin to the right of the main harness ....
Old Sep 23, 2004 | 06:27 PM
93civicEX's Avatar
for mine. What I did was go to the fuse box, and look for place that was empty. Then took a test light, and hooked it up to ground, So when I turned the key on, I looked for a empty socket, that was Off when the key wasn't on, and then On when the key was switched to the on postion. And then used a spade terminal, (i think whats what it is, The one that looks like a 2 prong fork) and used that as the lead. Never had any problems, To be on the safe side, Run a fuse inline
Old Sep 24, 2004 | 08:12 AM
PlastikOwl
Guest
Posts: n/a
Default Re: (93civicEX)
why the hell does an LED need constant power? Is it going to "forget" something?
Old Sep 24, 2004 | 09:55 AM
.ShawnD.'s Avatar
im pretty sure it works like this .. when hooked up the way they want .. the led stays off when the cars on.. and turns on when the cars off.. kinda like a turbo timer.
im probably making this alot harder then it is but i just wanted to see what would be the best thing to connect it to.. the red and yellow work in conjuntion like grounds.. idk
Old Sep 24, 2004 | 02:10 PM
rjr162's Avatar
Default Re: (.:s h a w n D:.)
so you just need to connect yellow to an accessory or ignition wire by the sounds of it. The easiest option would be tag into the one behind your head unit.
Old Sep 24, 2004 | 06:15 PM
.ShawnD.'s Avatar
thats what i was thinking.. except its a stock acura cd player.. i figure out somthing.. thanks for all the help though!!
Asmar
Audio / Security / Video
Feb 1, 2012 06:18 AM
almostjdmeg
11
Oct 22, 2008 09:04 AM
Si_chRis
Jun 24, 2006 03:59 PM
syked
Nov 15, 2005 10:47 AM
T04-Terror
Jul 22, 2003 09:12 AM
