HELP!!! I'm a newbert when it comes to this....
Old Sep 19, 2002 | 08:54 AM
tofaroni's Avatar
Default HELP!!! I'm a newbert when it comes to this....
I need to know what kind of amp will work best with what I have right now... I have a Pioneer headunit.. go to this link to see it and the specifics as far as power and stuff (because I don't know what any of that **** means):
http://www.crutchfield.com/cgi-bin/S...s&i=130DEHP840
I also have a Pioneer box with two 10'' subs, two mids, and two tweets in it also. Looks as if it was at one time a package from Pioneer, being that the actual box had "Pioneer" all over it. I bought of all this stuff off of my friend (with the exception of the new headunit), so that's mainly the reason I don't have that much information on it. I just need to get a new amp. I had a Pioneer 800 watt amp, but it broke so I wanted to know if there was something better I could get. I'm just using the amp for the box if that makes a difference in any way. I couldn't tell you any more specifics than that. Sorry for not knowing much... ...hopefully there's someone out there with a good, affordable opinion on what I should get.
Here's a long shot... anyone know how to cure the vibration sound that the rear deck gives off in a '99 Civic coupe? The buzzing KILLS me, but it only does it when there is no pressure on the deck (i.e. no one sitting in the back seat). I think it was actually listed as a recall. Any suggestions?
Thanks in advance.
Old Sep 19, 2002 | 02:03 PM
Bigjon
Guest
Posts: n/a
Default Re: HELP!!! I'm a newbert when it comes to this.... (tofaroni)
If i was you I would try to find out on the internet what the power handling is on the subs that you have(Watts RMS) then get a two channel amp that puts out enough to for the subs. And when you hook it all up disconnect the mids and tweets that are in the box, cause if you have it in the trunk you wownt hear them anywyas
cpl rampage
Audio / Security / Video
10
Jun 22, 2009 04:58 AM
DLudist
19
Apr 27, 2006 12:45 AM
blacK_Dc4
Jan 2, 2006 08:46 PM
cvclover
10
May 26, 2004 09:04 AM
tofaroni
Sep 19, 2002 08:50 AM
