Help with HID light problem
Old Apr 29, 2006 | 11:16 PM
srv777's Avatar
Default Help with HID light problem
Hope that someone can help with this problem I am having with HID lights not switching on when the car is on. This is happening on a 2002 Civic 4 door with McCoullough ballasts and bulbs. The weird thing is that I can turn on the lights, then turn on the engine, and everything is okay, but not have the engine running before turning on the lights.
I have checked the fuses with nothing blown, plus this kit was used in 2 previous cars with no issues.
Any help would be greatly appreciated!
Old May 2, 2006 | 04:05 PM
JSPECSIR's Avatar
Default Re: Help with HID light problem (srv777)
do they get power off of the original headlight wiring or is it through a relay to draw directly off of the battery?
Old May 2, 2006 | 05:55 PM
B18C_EJ8's Avatar
Definitely need to know where you're getting your power from....
Old May 2, 2006 | 07:45 PM
srv777's Avatar
Default Re: (B18C_EJ8)
Power is through the stock wiring. I have tried removing the fuse for DRLs and so far it is more consistent so hope for the best!
Old May 3, 2006 | 03:31 AM
JSPECSIR's Avatar
Default Re: (srv777)
you need to use the stock wiring to turn on relays that give the ballasts power directly from the battery, and fuse accordingly.
jk7701
Jun 7, 2010 05:10 PM
redcivic13
Lighting
May 5, 2009 02:45 PM
Infamous_Imports
Lighting
Feb 5, 2008 08:31 AM
97ekcoupe
Mar 23, 2007 04:28 PM
chinese buffet
Oct 16, 2005 08:09 PM
