HELP, electrical problem!
Old Aug 21, 2013 | 12:14 PM
fanaticalK's Avatar
Default HELP, electrical problem!
OK, this is pissing me off. i changed my battery the other day now my car is all jacked up. Lets start with me changing and pulling batts for years n years to removes tannys ect. never have i had anything happen. 1st, every light on the car works jus fine except for the low beams. no headlights, highs works fine along with everything else. i checked a few things, fuses n relays r good. 2nd, radio will not tune a station. yes i put the code in! every preset lets u listen to the same wrong channel on every station. sat. radio wont work either. blower motor noise, blinker, sunroof all can be heard thru the speakers when in use. wtf???
Old Aug 21, 2013 | 03:41 PM
toyomatt84's Avatar
Sanji
Default Re: HELP, electrical problem!
What kind of car is this?
Old Aug 22, 2013 | 11:28 AM
YeastLords's Avatar
Have you measured your battery voltage with a volt meter?
If you haven't, first measure the voltage with the engine at idle in order to verify that your charging system (alternator) is working properly. 13.5 - 14.5 volts at idle is typically representative of a properly functioning alternator.
After you've verified that the above checks out, measure your battery with the engine off. 12.6 volts would indicate a properly charged battery with the engine off.
Old Aug 24, 2013 | 08:27 AM
fcm's Avatar
fcm
Old Fart
Sounds like a grounding problem, check your main grounds.94
Old Aug 25, 2013 | 04:53 PM
fanaticalK's Avatar
sorry, its 06 rsx s.
i checked the grounds, everything is intact. no burn marks or anything.
i have no volt meter but everything else on the car works perfectly fine. not even a dim of the headlights when fan and a/c kicks on.
Old Aug 25, 2013 | 04:57 PM
fanaticalK's Avatar
the headlight problem ended up being both bulbs blown. which is pretty weird to me. ive never blown as much as a fuse while pulling batts let alone blowing bulbs out.
it gets even better....now i have a CEL. the scanner wont read at all or pull a code.
matt965
Honda Fit
Apr 9, 2017 07:50 PM
aznsins88
Sep 13, 2004 09:13 PM
Behan
Jul 17, 2003 03:33 PM
bluesaint
Mar 6, 2003 09:38 AM
TeH PLAYA
Feb 8, 2003 11:43 PM
