Help With Deck Installation
Old Apr 13, 2004 | 04:41 PM
B18Booyah's Avatar
Default Help With Deck Installation
help me out guys... just bought a new deck... wired her up, seemed to be working fine... but when i switch from radio to cd, my amp turns off... however, when im listening to radio, amp stays on... another thing that i found odd is that the damn thing stays on even without the keys in the ignition... i have to manually turn it off... i know i did something wrong...can anyone help??? thanks in advance
its an Alpine CDA-9815 btw...car is a 98 Integra
all suggestions much appreciated.
Old Apr 13, 2004 | 07:04 PM
..::91TEG-G2::..'s Avatar
Default Re: Help With Deck Installation (B18Booyah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Booyah &raquo;</TD></TR><TR><TD CLASS="quote">help me out guys... just bought a new deck... wired her up, seemed to be working fine... but when i switch from radio to cd, my amp turns off... however, when im listening to radio, amp stays on... another thing that i found odd is that the damn thing stays on even without the keys in the ignition... i have to manually turn it off... i know i did something wrong...can anyone help??? thanks in advance
all suggestions much appreciated.</TD></TR></TABLE>
well if it stays on, its hooked up to a constant power source like a power wire.... u need to look for a blue wire comming from the deck.. blue or baby blue, might not come from the harness, but directly from the deck.. hook it up to there and it should be fine.. also called remote turn on wire or power antenna
Old Apr 13, 2004 | 07:53 PM
B18Booyah's Avatar
thanks alot...any ideas about the amp situation?
Old Apr 13, 2004 | 08:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Booyah &raquo;</TD></TR><TR><TD CLASS="quote">thanks alot...any ideas about the amp situation?</TD></TR></TABLE>
uhh, amp should be fine.. also make sure u have no stray wires from the power side reaching over onto the remote turn on wire/power antenna because trust me, one little wire over onto that side can keep it on also.. umm other then that, that should be it, and it should work fine.. doesnt sound like an amp problem.. just a wireing problem, easily messed up but also an easy fix..
try it and let me know what happens.. good luck!!
Old Apr 14, 2004 | 06:57 AM
B18Booyah's Avatar
thanks man, ur advice worked... the initial problems were fixed... but now my rear speakers dont work... good lord, im such a newbie when it comes to car audio installation ... anyone know what colour the wires are for the rear speakers?
thanks in advance
Old Apr 14, 2004 | 07:11 AM
nOOber's Avatar
in the car, or the deck?
deck rear outputs should be:
driver side greens
passenger side purples
Old Apr 14, 2004 | 10:54 AM
AndyGCT's Avatar
Default Re: Help With Deck Installation (nOOber)
buy a damn wiring harness then match color to color...Makes life so simple...Then get a amp that you hook up RCA;s to not no bogus style like hooking up the rears...You'll fry those wires plus they wont be able to send that strong of a signal to it...
Old Apr 14, 2004 | 01:15 PM
Default Re: Help With Deck Installation (AndyGCT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyGCT &raquo;</TD></TR><TR><TD CLASS="quote">buy a damn wiring harness then match color to color...Makes life so simple...Then get a amp that you hook up RCA;s to not no bogus style like hooking up the rears...You'll fry those wires plus they wont be able to send that strong of a signal to it...</TD></TR></TABLE>
bro, chill.. some wiring harnesses have bare wires on the other end, that u hook up the speakers too.. and some dont..
just let him do it this way, he's almost done anyways..
Old Apr 14, 2004 | 02:18 PM
B18Booyah's Avatar
i did buy a harness actually... and i do have an amp, but it's only powering my front speakers...i have a mono amp for my sub...was planning on running the rear speakers from the deck... thanks for the suggestion anyway tho... i know this may be really simple to you guys but this is my first crack at anything to do with car audio so excuse the newbieness please...
anyway, the rear speaker wires were purple/green... i had wired them right, so i just rewired incase there was a bad connection... but still no cigar... no rear speakers... so i guess i fried the wire like someone mentioned??? any other suggestions or should i just bite the bullet and pay a pro to do it?
thanks for your advice and patience btw dudes
Old Apr 14, 2004 | 07:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Booyah &raquo;</TD></TR><TR><TD CLASS="quote">i did buy a harness actually... and i do have an amp, but it's only powering my front speakers...i have a mono amp for my sub...was planning on running the rear speakers from the deck... thanks for the suggestion anyway tho... i know this may be really simple to you guys but this is my first crack at anything to do with car audio so excuse the newbieness please...
thanks for your advice and patience btw dudes</TD></TR></TABLE>
u know what.. also, heres a couple of things u can take into concideration..
1) make sure ur deck settings are correct, that the fade isnt alway to the front..
2) if ur front speakers are very loud, u might not hear anything out of them..
3) double check to make sure ur rca's are plugged into the front outputs from the back of the deck..
4) make sure wire connection is clean from any snips..
5) make sure speaker wire is still plugged in the speakers..
not sure if any of this is you.. but there possibilitys that u might wanna check out.. if not.. then u got me stumped
goodluck
Old Apr 15, 2004 | 07:39 PM
B18Booyah's Avatar
Default Re: Help With Deck Installation (..::91TEG-G2::..)
thanks for all the suggestions guys...especially 91 teg... but i figured it out on my own... fixed... i just pulled it all apart and started all over... guess i fucked up with a few connections somewhere along the way... but its working properly now, rear speakers and all...
thanks again for all the suggestions though
hondaZvic
Audio / Security / Video
10
Feb 13, 2007 12:17 PM
Jdmglenn
Oct 24, 2006 11:18 AM
Aaron.
Aug 30, 2003 07:43 AM
acuraLSSE95
Nov 4, 2002 06:07 PM
SoCal ITR
Dec 3, 2001 04:54 PM
