Help with deck
Old Aug 21, 2005 | 10:34 AM
TheTealHatch's Avatar
Default Help with deck
hey you guys.. how do you guys remove an aftermarket deck... without buying those 2 pins to pull them out.. cause i dont want to pay for them 2 pins and just use it only once.. thanks
Old Aug 21, 2005 | 01:43 PM
devilduck's Avatar
What kind of car and deck is it? It migth be possible to take the console appart and then remove the dash kit so you can get at the cage and just bend the tabs with a screw driver.
Old Aug 21, 2005 | 04:31 PM
mikedd_87's Avatar
Default Re: (devilduck)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilduck &raquo;</TD></TR><TR><TD CLASS="quote">What kind of car and deck is it? It migth be possible to take the console appart and then remove the dash kit so you can get at the cage and just bend the tabs with a screw driver.</TD></TR></TABLE>
Old Aug 21, 2005 | 11:04 PM
Default Re: (mikedd_87)
94 eg hatch alpine 9843..
how do you take off the console?
Old Aug 22, 2005 | 10:17 AM
Default Re: (ackavong)
any one?? i need help...
Old Aug 22, 2005 | 11:08 AM
fcm's Avatar
fcm
Old Fart
There are no keys for an Alpine HU, remove faceplate and faceplate trim. look on the left and right of the HU, you will see the HU "locks", [spring loaded locking pins] lift pins to center position, pull HU out, if HU was installed properly there should also be a back support, it will have to disconnected before HU will pull out of sleeve. 94
Old Aug 22, 2005 | 06:47 PM
Default Re: (fcm)
any other ways...?? ill try that..
Old Aug 22, 2005 | 07:52 PM
romoracing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ackavong &raquo;</TD></TR><TR><TD CLASS="quote">any other ways...?? ill try that..</TD></TR></TABLE>
plasma cutter. lol, jk. Fcm is correct there is like 4 screws behind the trim
Old Aug 22, 2005 | 10:35 PM
Default Re: (romoracing)
im kind of not understanding but i kinda get the idea.. you tihnks you guys got pictures.. to kinda show me... thanks it would be REALLY helpful to me
Old Aug 23, 2005 | 08:39 AM
fcm's Avatar
fcm
Old Fart
Sorry no pix, but try this, go here http://www.alpine.com, click on North America, then on Tech Center, then on Consumer Site, then where it says Quick Search, type in CDE-9843, when it comes up, click on the down load, scroll to page 22, and say WTF , an Alpine that uses keys WTF anyway my mistake, go and get a pr. of butter knifes out of the kitchen drawer, after removing the faceplate trim ring, slide a knife down each side of the HU, between the unit and the sleeve, about 2" , that will release the "lock" tabs that are on the sleeve, that "push" into the HUs sides.
Sorry for the wrong info the first time, but that's a new one for me 94
Old Aug 23, 2005 | 12:14 PM
Default Re: (fcm)
haha its cool..thanks for the info though.. so then it should just slide out ?? or once its unlock pull/push it out right??
Old Aug 23, 2005 | 03:19 PM
fcm's Avatar
fcm
Old Fart
Once "locking tabs" are pushed aside, the HU will "pull" out, but like I said if it was installed properly there will be a back brace, and if that was done properly, it will not slide out very much at all, if any. 94
JackRabbit
Nov 7, 2008 11:33 AM
daveng
Acura TL, RL & ZDX
Jul 6, 2007 02:20 PM
sheekdude
Acura TL, RL & ZDX
Nov 10, 2006 03:36 AM
JumboJoe
Audio / Security / Video
Jun 10, 2003 04:46 AM
slowacura
Apr 19, 2003 08:44 PM
