Help with deck
hey you guys.. how do you guys remove an aftermarket deck... without buying those 2 pins to pull them out.. cause i dont want to pay for them 2 pins and just use it only once.. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devilduck »</TD></TR><TR><TD CLASS="quote">What kind of car and deck is it? It migth be possible to take the console appart and then remove the dash kit so you can get at the cage and just bend the tabs with a screw driver.</TD></TR></TABLE>
There are no keys for an Alpine HU, remove faceplate and faceplate trim. look on the left and right of the HU, you will see the HU "locks", [spring loaded locking pins] lift pins to center position, pull HU out, if HU was installed properly there should also be a back support, it will have to disconnected before HU will pull out of sleeve.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ackavong »</TD></TR><TR><TD CLASS="quote">any other ways...?? ill try that..</TD></TR></TABLE>
plasma cutter. lol, jk. Fcm is correct there is like 4 screws behind the trim
Sorry no pix, but try this, go here http://www.alpine.com, click on North America, then on Tech Center, then on Consumer Site, then where it says Quick Search, type in CDE-9843, when it comes up, click on the down load, scroll to page 22, and say WTF
, an Alpine that uses keys WTF
anyway my mistake, go and get a pr. of butter knifes out of the kitchen drawer, after removing the faceplate trim ring, slide a knife down each side of the HU, between the unit and the sleeve, about 2" , that will release the "lock" tabs that are on the sleeve, that "push" into the HUs sides.
Sorry for the wrong info the first time, but that's a new one for me
94
anyway my mistake, go and get a pr. of butter knifes out of the kitchen drawer, after removing the faceplate trim ring, slide a knife down each side of the HU, between the unit and the sleeve, about 2" , that will release the "lock" tabs that are on the sleeve, that "push" into the HUs sides.Sorry for the wrong info the first time, but that's a new one for me
94
Once "locking tabs" are pushed aside, the HU will "pull" out, but like I said if it was installed properly there will be a back brace, and if that was done properly, it will not slide out very much at all, if any.
94
94
JackRabbit
Nov 7, 2008 11:33 AM
