Help on choice of amp
Old Nov 8, 2004 | 07:07 AM
NavyHonda95's Avatar
Default Help on choice of amp
whats the best amp i could get for $200?
thanks for the help
Old Nov 8, 2004 | 07:19 AM
sopiwnykg's Avatar
Default Re: Help on choice of amp (NavyHonda95)
2 channel, 4 channel, mono, new, used? Kinda need some info to help you out.
Old Nov 8, 2004 | 07:55 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NavyHonda95 &raquo;</TD></TR><TR><TD CLASS="quote">whats the best amp i could get for $200?
thanks for the help </TD></TR></TABLE> Yea more info, for sub amp as many watts as you can get for $200, for highpass/fullrange as "clean" or "good" an amp as you can get for $200 94
Old Nov 8, 2004 | 08:42 AM
chucksnee's Avatar
Default Re: Help on choice of amp (fcm)
Yep need more info....
Sub amp, you can get the JBL 1200.1 MONO amp for under $200.
Old Nov 8, 2004 | 11:25 AM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Yea more info, for sub amp as many watts as you can get for $200, for highpass/fullrange as "clean" or "good" an amp as you can get for $200 94</TD></TR></TABLE>
while more power for the sub is generally better you have to watch out for the power rating on some of the cheaper amps. you've probably seen just as much as i have, amps that claim 1000W or more and have somethign like a 50amp fuse or less.
Old Nov 8, 2004 | 02:50 PM
fcm's Avatar
fcm
Old Fart
Default Re: Help on choice of amp (EBP_SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">
while more power for the sub is generally better you have to watch out for the power rating on some of the cheaper amps. you've probably seen just as much as i have, amps that claim 1000W or more and have somethign like a 50amp fuse or less.</TD></TR></TABLE>Dito that 94
JDMcivicSiEG6
Audio / Security / Video
Mar 12, 2008 09:02 PM
{Powered by VIII}
27
Jan 15, 2006 09:10 AM
_Justus
15
Mar 30, 2005 07:50 AM
NavyHonda95
Oct 22, 2004 04:31 AM
Ludeboi
Aug 26, 2004 06:57 PM
