Help with alarm install...
Old Aug 21, 2002 | 05:40 PM
technine's Avatar
Default Help with alarm install...
I need help with tapping into my door pin wire in my 89 civic hatch. I know the color is green/red, but when I tapped into the green/red wire under the dash it didn't give a signal when the door was open. It did give a signal at the actual door pin with the same color wire connected to it. What is going on?
Old Aug 21, 2002 | 07:34 PM
twogengsr's Avatar
Default Re: Help with alarm install... (technine)
the wire you looking for in in the drivers kick low down it lookls really thick but is mostly insolation it is light green with a red stripe the witre your tapping into HAS to be dark green with a red stripe the wrong wire
Old Aug 22, 2002 | 11:30 AM
technine's Avatar
Default Re: Help with alarm install... (EVIL Teken)
You are tapping into the wrong harness point... It should be connected to the passenger side door input...
EVIL Teken...
So your saying to tap into the passenger side wire? Where is that located near the dash? Or should I just tap from the door pin itself?
Old Aug 22, 2002 | 11:31 AM
technine's Avatar
Default Re: Help with alarm install... (twogengsr)
So you are saying that the dark green/red is wrong? I took off the door pin switch at the door and it is dark green/red, too. Didn't see the light green red one though. It's down low behind the drivers kick panel? I will check that.
Old Aug 22, 2002 | 10:09 PM
HandCommand's Avatar
What twogengsr said is correct. Its a thicker light green wire with red stripe. This can be found under the carpet near the drivers lower kick panel. It should show 12 volts at rest, and should test "ground" when either door is opened.
Make sure the door contact switches are working properly first.
SilverEK96
Audio / Security / Video
Jun 6, 2012 03:54 PM
ryanplayjoint
11
Apr 4, 2011 04:59 PM
kcjohnnyboy
27
May 10, 2008 08:30 AM
apm
Feb 19, 2005 12:50 PM
DocYahoo
15
Jul 20, 2002 04:29 PM
