Help with Alarm Install....
Old Feb 5, 2007 | 12:41 PM
92GSRciv's Avatar
New User
Default Help with Alarm Install....
I have a 95 Integra GSR...
I am installing a New Clifford Matrix 10.5X into it this weekend.
Im wondering if anyone has a wiring diagram for the OBD I integra? Or where to get one? I dont wanna just start splicing wires ya know!!!
And if anyone has installed one of these before, some notes would be good!
thanks!
Old Feb 5, 2007 | 01:33 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Help with Alarm Install.... (92GSRciv)
1995 Acura Integra Security Information
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Ignition 2 White/Black Ignition Switch Harness
Accessory Yellow Ignition Switch Harness
Tach Blue Distributor
Neutral Safety Wire Green/White Gear Select Switch
Brake Switch Green/White Brake Switch
Trunk Pin Green (-) Driver's Kick Panel or Factory Alarm
Parking Lights Red/Green Green Connector above Fuse Panel
Head Lamp Red/White Steering Column low beam
Hood Pin n/a
Factory Disarm With Keyless Entry
Door Trigger Green/Red (-) Driver's Kick Panel or Factory Alarm
Door Lock Black/White (-) Driver's Kick Panel
Door Unlock Black/Red (-) Gray Connector behind Cruise Control Module
Horn Wire Blue/Green (-) Steering Column
Windows Up LF=Red/Yellow, RF=Blue/Red, LR=Green/Yellow, RR=Yellow
Windows Down LF=Red/Blue, RF=Blue/White, LR=Green, RR=Yellow/Green
Make sure you throw a back up battery on the install and put the siren in the fender were it can not be gotten to. Make sure you have the tools to do the job and a dvm to test your wires. Never use a test light. It could cost you more in the end. If you have any doubts on the job don't do it and take it to someone that knows what they are doing.
Old Feb 5, 2007 | 01:36 PM
92GSRciv's Avatar
New User
Default Re: Help with Alarm Install.... (wrx-killer-Sti eater)
rock on! I gots it all, I have done lots of installs, just not on any integras...
thanks much!
Old Feb 5, 2007 | 02:02 PM
np
Old Feb 6, 2007 | 06:47 AM
fcm's Avatar
fcm
Old Fart
http://www.directwholesale.net...eID=6 GL on the install. 94
Old Feb 6, 2007 | 04:43 PM
92GSRciv's Avatar
New User
Default Re: Help with Alarm Install.... (fcm)
thanks for the info!!!
Do you guys know what wires on the teg you use for Remote start?
thanks
Old Feb 6, 2007 | 08:08 PM
Poptart's Avatar
directechs.com
Old Feb 7, 2007 | 06:49 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92GSRciv &raquo;</TD></TR><TR><TD CLASS="quote">Do you guys know what wires on the teg you use for Remote start?
thanks</TD></TR></TABLE> There are a number of them, in your case...
1- White 12V+ constant
2- Black/white starter
3- Black/yellow ign. 1
4- Yellow acc. 1
5- Red/black park light pos.(+), also found at park light free pin on under dash fuse box.
6- Light green/red neg.(-) door trigger, only needed is a standard transmission.
7- Blue tach.
8- and not listed the parking brake, ["E" or hand brake] probably a green/red at hand brake switch, also only if your car is a 5 speed. 94
A hood pin will also have to be installed, hood pin, door trigger and park lights will also work for alarm. 94
Old Feb 7, 2007 | 09:27 AM
92GSRciv's Avatar
New User
Default Re: Help with Alarm Install.... (Poptart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Poptart &raquo;</TD></TR><TR><TD CLASS="quote">directechs.com </TD></TR></TABLE>
Need a dealer password....
Old Feb 7, 2007 | 10:18 PM
92GSRciv's Avatar
New User
Does anyone know the color of the blinker wires? I want my blinkers to blink when the alarm arms instead of the taillights...
Thanks!
Old Feb 8, 2007 | 05:29 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92GSRciv &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know the color of the blinker wires? I want my blinkers to blink when the alarm arms instead of the taillights...
Thanks!</TD></TR></TABLE> Why, it will require relays or big *** diodes, to isolate the left and right sides, use the park lights, single plug-in, [park light free pin in under dash fuse box] not relays or diodes needed. 94
Thug_life
Audio / Security / Video
Dec 5, 2011 06:19 AM
EFPimpin
Sep 17, 2010 03:55 AM
phillybeats.com
Jun 25, 2004 06:47 AM
RAK
Apr 24, 2004 04:11 AM
