Headunit won't turn on
Old Feb 28, 2005 | 09:15 PM
em1 Ziggy's Avatar
Default Headunit won't turn on
i just installed my amp... all i needed was too put in my amplifier remote wire.. so i took out my harness wire and plugged the blue wire with blue.. and then that didn't work so i decieded to put my remote in the fuse box.. and i plugged it on and boom i got my amp to turn on.. but my After market HU won't turn on!!! anyone know what i did wrong?
Old Feb 28, 2005 | 10:05 PM
em1 Ziggy's Avatar
Default Re: Headunit won't turn on (eK Ziggy)
bump! for a good night to all
Old Feb 28, 2005 | 11:56 PM
EVOLMTR's Avatar
Did you check your fuse box for any blown fuses? Check to see if your getting 12V constant and 12V acc behind the radio.
Old Mar 1, 2005 | 08:03 AM
Catera's Avatar
Default Re: Headunit won't turn on (EVOLMTR)
hes exactly right check all fuses you can blow them if you touch the constant power ( yellow) or blue wires to something else when the radio was plugged in. check all inside fuses and under the hood.
Old Mar 1, 2005 | 02:39 PM
itr_dc2's Avatar
Default Re: Headunit won't turn on (Catera)
test your wires, if you are still getting the 12v, check to see if you pulled out any pins in your radio harness
Old Mar 1, 2005 | 07:41 PM
em1 Ziggy's Avatar
Default Re: Headunit won't turn on (itr_dc2)
i got the problem.. its a blown fuse!!! thank you
Old Mar 1, 2005 | 07:59 PM
EVOLMTR's Avatar
glad you figured it out.
Steven P
May 7, 2016 02:36 AM
vtak2nr
Audio / Security / Video
Sep 8, 2011 08:02 PM
kirkland08
Jun 17, 2010 09:12 PM
646EG
Aug 30, 2007 09:20 PM
Rhymenoceros
10
Oct 13, 2006 06:41 AM
