headunit turns off
Old Aug 16, 2005 | 11:33 PM
LAOS's Avatar
Default headunit turns off
i have a 96 gsr with alpine cda-9851 headunit, jl 500/1 amp, 12" type r sub, and 2 pairs of infinity speakers. monster 4 gauge amp wire kit
<U> Every time i turn up my system too loud the headunit turns off dose anyone know what the problem is? </U>
Old Aug 17, 2005 | 04:19 AM
vicn77's Avatar
Default Re: headunit turns off (LAOS)
does it turn off or does the sound turn off and the radio stay on?
make sure you have a good ground and power going into it. i know the alpines need a good ground and power source.
Old Aug 17, 2005 | 07:49 AM
mikedd_87's Avatar
mine did/does the same thing when turn(ed) it up too loud, it just shut the audio off, does yours completely shut off, no power what so ever?
Old Aug 17, 2005 | 08:08 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAOS &raquo;</TD></TR><TR><TD CLASS="quote">i have a 96 gsr with alpine cda-9851 headunit, jl 500/1 amp, 12" type r sub, and 2 pairs of infinity speakers. monster 4 gauge amp wire kit
<U> Every time i turn up my system too loud the headunit turns off dose anyone know what the problem is? </U> </TD></TR></TABLE>Two things I would look at, the first I would do, if not already done, if the HUs constant power, [yellow] is wired to the oem radio harness, it needs to be moved, run a 12ga or 10ga fused power wire from the batt. to behind the HU and connect the yellow to it, [just like the amp is wired] also run the same gage ground wire from the chassis of the HU to the chassis/ground point of the car, [as close to the HU as possible] even if it is not the problem, the speakers that the HU is running will sound better and get louder.
The other thing I would look for is a short, on one or more of the speakers or speaker wires, make sure the speaker term. are not touching the chassis of the car, [a common problem when installing some aftermarket speakers in Honda/Acuras] 94
Old Aug 17, 2005 | 09:01 AM
sqad_7's Avatar
Default Re: headunit turns off (fcm)
My head did this when i connected the remote wire from the amp to the power wire in the headunit. Any time i hit a bump the deck cut off, now that i unhooked it everthing is fine just no bass.
Old Aug 17, 2005 | 12:40 PM
fcm's Avatar
fcm
Old Fart
Default Re: headunit turns off (sqad_7)
What kind of HU? 94
Old Aug 17, 2005 | 01:20 PM
LAOS's Avatar
Default Re: (mikedd_87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikedd_87 &raquo;</TD></TR><TR><TD CLASS="quote">mine did/does the same thing when turn(ed) it up too loud, it just shut the audio off, does yours completely shut off, no power what so ever?</TD></TR></TABLE>
yes it just shuts off completly then turns on again
Old Aug 17, 2005 | 06:23 PM
mikedd_87's Avatar
what shuts off? the power or the sound?
Old Aug 18, 2005 | 11:00 AM
flowbee's Avatar
From Carreview.com
Reviewed by: bluzapper
Year: 2004
Model: cda-9851
Price Paid: $302 at best buy
Summary:
Alpine need I say more. I am very disappointed...I owned an alpine cd player for the last 3 years and had absolutely 0 problems. The moterized face worked flawlessly and was never in question on weather or not it would turn on. This new line of alpine has seriously shaken my confedence in alpine as a whole. Since I purchased this player I have had to return and exchange twice...first due to the motorized face stopped working...the second time because it would turn off from time to time and the face would only work sometimes....and i would have to take the plate off wait a few minutes and try again. I am installing my third 9851 tonight ...I hope third times the charm.
Strengths:
Sound quality and versatility
Weaknesses:
Usage of this product proved to be a chore....very criptive menu's
Similar Products Used:
Old Aug 18, 2005 | 11:35 AM
LAOS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikedd_87 &raquo;</TD></TR><TR><TD CLASS="quote">what shuts off? the power or the sound?</TD></TR></TABLE>
THE POWER
Old Aug 18, 2005 | 01:44 PM
fcm's Avatar
fcm
Old Fart
Default Re: (LAOS)
THE POWER</TD></TR></TABLE> If you mean the HU turns off, like when you turn off the ign., [no lights or anything on on the HU] but memory for the clock and radio presets are still good, then there is a problem with power on the acc., [red wire to the HU]
If you mean no sound, but the HU still has lights and a read out on the face plate, it may be a short in a speaker or speaker wire and the HUs protection circuits are kicking in.
I you mean no sound and/or no read out on the face plate, and you lose the clock and radio pre sets, there is a problem with power on the HUs constant power, yellow, this is a common problem when todays "high power" HU get there constant power from the stock radio harness, [ this will only happen if you are using the HUs internal amp]
Which one of the above is it, in your case. 94
Old Aug 18, 2005 | 09:50 PM
LAOS's Avatar
Default Re: (fcm)
iono my headunit just turns off when i turn up my volume then turns back on continuing where it left off and it will turn off again if i don't turn down the volume a little bit the max i can go too is 20.
thanks for the help FCM
Old Aug 19, 2005 | 06:45 AM
fcm's Avatar
fcm
Old Fart
Default Re: (LAOS)
I understand that the HU turns off, what I need to know is, which of the 3 options I gave you is the case with your HU 94
Old Aug 19, 2005 | 08:49 AM
LAOS's Avatar
Default Re: (fcm)
The first option lol sorry bout that
ws350z
Audio / Security / Video
Sep 26, 2008 09:35 PM
ef_88_hatch
13
Sep 13, 2008 12:53 PM
skingfreak
12
Dec 5, 2007 06:05 PM
.David
Apr 16, 2005 04:20 PM
SuperMan19
Mar 9, 2002 12:05 AM
