Headunit problem
Old Jan 12, 2008 | 08:05 AM
Boarderx192's Avatar
Default Headunit problem
Im not really a newb when it comes to wiring in a after market head unit but Im having a newb issue.
I have a Clarion DXZ745MP in my car as well as in my GF's car. Its an awesome headunit for the everday person because it has almost everything you could ever want in a HU.
When I installed the head unit, I bought the adapter harnesses from Circuit city and connected the HU harness that was supplied with the HU by twisting the ends together and then soldering the connection and then I used electrical tape to cover the exposed wire. The only wires I didnt do this too were the power and the ground. For those I used male and female end crimps and then used the electrical tape to cover the exposed surface. The radio in my car works perfectly, I couldn't be happier with it. However, the HU that is in my GF's car is having issues.
The volume range on these HU's go from 0-33. I usually listen to the music at 18-24 depending on road noise, people in the car, etc.. When you turn up the volume on her HU, RIGHT AT 22 it starts to crackle and distort. I thought it could be the speakers but when I checked them out, they seemed fine. Then I thought it was the HU so I took my HU out of my car and installed it in her car. Still had the same problem with the crackling.
Then I figured that it was the wiring. I took off the tape on the power and ground and saw that the ground wire seemed to be coming loose so I took off the male/female connectors and twisted the two together and used electrical tape to cover the exposed wire. It worked perfectly for a while but now the same issue has come back. I tried checking the ground wire again and it seems to be in good condition so Im sorta ruling that out.
What should I do next? What could be causing the crackling?
Old Jan 14, 2008 | 08:00 PM
Default Re: Headunit problem (Boarderx192)
Bump, someone here has got to know what I can do.
Old Jan 15, 2008 | 05:17 AM
White Smoke's Avatar
i my honda
Global Mod
How did you check out the speakers? Try turning up the stereo past 22 with the HU pulled from the dash and move the wires around where you made your connections. See if it gets better or worse. Try and isolate the wire or wires causing the issue.
acardboardllama
Jul 11, 2013 10:28 AM
RedHurricane
Audio / Security / Video
Jan 31, 2011 09:51 PM
iJDMBB6
Mar 17, 2009 05:57 PM
Re3irth
May 13, 2004 07:31 PM
nightryder21
Jan 28, 2004 06:21 PM
