Headunit/Keyless Entry Question (searched)
Old Nov 12, 2004 | 07:58 AM
Honda_Driver's Avatar
Default Headunit/Keyless Entry Question (searched)
Awhile back i installed a sony xplod headunit in the bottom slot of my 97 civic ex so i could keep my stock headunit and have keyless entry. Now i want to put my xplod headunit in the factory slot so i can use my cupholders. Ive tried to stuff the factory headunit behind the dash but there is just not enough room. Is it possible i can take the outer casing off the factory headunit and wrap it up? Do you guys have any other suggestions? By the way i did search.
Old Nov 12, 2004 | 07:23 PM
fcm's Avatar
fcm
Old Fart
Default Re: Headunit/Keyless Entry Question (Honda_Driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_Driver &raquo;</TD></TR><TR><TD CLASS="quote">Awhile back i installed a sony xplod headunit in the bottom slot of my 97 civic ex so i could keep my stock headunit and have keyless entry. Now i want to put my xplod headunit in the factory slot so i can use my cupholders. Ive tried to stuff the factory headunit behind the dash but there is just not enough room. Is it possible i can take the outer casing off the factory headunit and wrap it up? Do you guys have any other suggestions? By the way i did search.</TD></TR></TABLE> Just get an alarm and wire it for keyless entry and remove the OEM HU. 94
Old Nov 12, 2004 | 09:49 PM
eastbay92cx's Avatar
Default Re: Headunit/Keyless Entry Question (fcm)
The stock deck will fit back there I've done it before. Get creative =]
Try behind the center console as far down as possible, to where if you stick your head down in either footwell area you will be able to see it.. good luck.
nuclidex
Feb 8, 2014 02:44 PM
CivicExMaster
Mar 2, 2008 03:44 AM
Honda_Cribb_GS-R
Audio / Security / Video
May 29, 2007 04:31 AM
Taimaishui14
Oct 10, 2006 11:21 AM
jennabee
Nov 7, 2005 09:19 PM
