HEAD UNIT WIRING...PLEASE HELP!!
i had wired the head unit the way i thought it was supposed to be according to the manual...but it wouldnt turn on...i had a good ground and everything was fine so i started playin around with things cuz i had a similar problem before but it never got resolved...
right now the only way for me to have the radio working is to have the the battery/memory and the ignition/acc cables wired together. but now my problem is that the radio doesnt come on automatically...and i have no memory...all the settings reset when the car turns off. im really stumped on this one so any help is appreciated
thanks in advance
thanks in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dizzyroc88 »</TD></TR><TR><TD CLASS="quote">i had wired the head unit the way i thought it was supposed to be according to the manual...but it wouldnt turn on...i had a good ground and everything was fine so i started playin around with things cuz i had a similar problem before but it never got resolved...
thanks in advance</TD></TR></TABLE> Check 7.5 amp fuse in engine bay fusebox.
Also if the HU is a "high power" unit, run constant power,[yellow] to batt., don't forget to fuse it.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dizzyroc88 »</TD></TR><TR><TD CLASS="quote">you just made my day... im gonna replace the 7.5 and hope everything turns out alright..it was blown</TD></TR></TABLE> Like I said if its a high power HU 7.5 amps may not be enough, you may have to run yellow to batt. DO NOT REPLACE WITH BIGGER FUSE.
94
94
