Head Unit Install
Old May 27, 2003 | 08:22 PM
darkvibe's Avatar
Default Head Unit Install
I picked up my '03 civic Si last friday and got a new head unit for it.
Is there anything I should know before I try to tear the dash apart to install it? Or is there somewhere that would have step by step instructions for taking everything apart? I can figure it out, but any info that will make it easier is appreciated. I found these directions in another post for a '00 Si, are they similar for my car?
1-remove paneling below the steering wheel. (3-philips)
2-remove glove box. ( 2-8mm) Or you can squeeze it until it falls below the bump stops.
3-remove center piece w/12v outlet (5-philips and 1-8mm)
4-locate and remove 4 8mm screws under the climate control cluster (ccc)
5-pull ccc out and remove all harnesses. At this point you will be able to totally remove this piece.
Also, should the pioneer DEH-P6500 fit with no problems? Crutchfield.com said that it was "easy" installation.
Old May 28, 2003 | 12:57 AM
Bigphlip's Avatar
Default Re: Head Unit Install (darkvibe)
yeah I was the one who posted that and I can tell you that it won't work with your dash. Sorry but don't try those directons. The 6500 will fit too.
Old May 28, 2003 | 08:29 AM
darkvibe's Avatar
Looks like i'll have to figure it out on my own. Oh well, i need an adventure.
thanks for the info.
Old May 28, 2003 | 12:59 PM
Aquaman's Avatar
Default Re: (darkvibe)
Go to http://www.k-series.com and the technical section. They have installation directions for the Si. I had to use em with my car and I still needed to do thinking on my own for it, since its a MASSIVE pain in the *** to do it. The two bolts holding the top half of the center console are on tighter then a 10 year olds ***. Took me about an hour just to get them off. Good luck, your gonna need it
Oh, I installed the 6500 as well
Old May 28, 2003 | 03:58 PM
darkvibe's Avatar
oh man. a kit. i need a dash kit. knew i forgot something. i went out to look for one today. i came home with a pioneer 6 disc changer but forgot the dash kit.
thanks for that link. it's perfect.
hondaPINK
Audio / Security / Video
Oct 29, 2006 08:27 AM
davidnguyen
Apr 26, 2005 09:05 AM
Intercooler
Dec 4, 2004 03:42 PM
Inaniac
Feb 25, 2004 03:35 PM
Richard.
May 28, 2003 12:55 AM
