Is this a good speaker?
Old Mar 5, 2003 | 09:55 AM
Sam's Avatar
Sam
Default Is this a good speaker?
So I got a deal for $85 for this Sony speaker and here is the spec:
6 1/2" HOP woofer cone: A proprietary Sony speaker cone material which combines high strength; low weight; and low resonance resulting in improved transient response; higher power handling; and flatter frequency response
2" Metal Midrange
1" PEI Balanced-Dome Tweeter
Built-in 2-way passive crossover: A component or circuit used to divide the audio signal into specific frequency bands
200 Watts Maximum Input Power (50W RMS)
High Compliance rubber surround
Aluminum Die-cast Frame: A speaker basket constructed from aluminum (for strength & high damping) using casting production techniques
Gold Plated binding posts
4 ohm voice coil
Sensitivity: 90 dB/W/m
Frequency Response: 30 - 28000 Hz
Weight: 1;180 g (2 lbs. 10 oz.) per speaker
Dimensions: 6 1/2" x 2 1/2"
What's a built in 2 wy passive crossover? I am very new to this so please help. Are they the same as those cross over component where there are two mid ranger speakers plus two tweater? Anyone has experience with this speaker?
I want to put it in the front and just use a lower cost at the rear, will it improve the sound qualifty?
Thanks
Old Mar 5, 2003 | 10:24 AM
King_j's Avatar
Default Re: Is this a good speaker? (Sam)
they look good, 50 watt rms, hope you use a amp otherwise thyll sound like stock speakers
Old Mar 5, 2003 | 10:25 AM
bryan305's Avatar
Default Re: Is this a good speaker? (King_j)
I love sony for their home equipment, but I LOATH their car audio stuff. (they call it explode for a reason )
Old Mar 5, 2003 | 10:32 AM
JOMO
Guest
Posts: n/a
put it this way, they are cheap but you can make them sound half-decent, i heard a friends explod system and it sounded great
i would recomend other brands but for that price i guess you did go od
Old Mar 5, 2003 | 10:33 AM
JOMO
Guest
Posts: n/a
Default Re: Is this a good speaker? (JOMO)
hold up, you paid $85 for the pair right??not just one??
Old Mar 5, 2003 | 10:58 AM
Sam's Avatar
Sam
Thank you very much for all the response!! You guys are great!!
Yes, just $85 included tax for a pair. I use a Sony CDX-MP70 without any amp, is that not a good idea? I just want something better than stock, not real high level component. So, do I need an amp??
Here is the spec for my deck:
Key Features:
detachable, fold-down face
dot matrix display
7 selectable display colors (aqua, blue, white, green, green-yellow, orange, and violet)
SSIR-EXA tuner
XM Satellite Radio controls (XM Radio subscription, tuner, antenna required to receive the satellite radio signal) — service not available in Alaska or Hawaii
CD/MD changer controls — add a Sony changer to your receiver order, and save $$ with Crutchfield's package discount
CD-R/CD-RW compatible
plays MP3 files recorded on CD-R/CD-RW
displays ID-3 tags
G-Protection — combines memory buffer, sealed CD chamber, and disc-gripping spindle
EQ7 features 7 bands of EQ (+/-10 dB at 62, 157, 396, 1,000, 2,500, 6,300, and 16,000 Hz) and 7 EQ presets ("Vocal," "Club," "Jazz," "New Age," "Rock," "Custom," and "Xplod")
Dynamic Soundstage Organizer (raises the soundstage of lower door-mounted speakers to dash level)
front, rear, and subwoofer preamp outputs
built-in high- and low-pass crossovers (selectable 78 or 125 Hz)
clock
wireless remote
23 watts RMS/52 peak x 4 channels
CD frequency response 10-20,000 Hz
CD signal-to-noise ratio 95 dB
FM sensitivity 8 dBf
1-year warranty
[Modified by Sam, 12:00 PM 3/5/2003]
Old Mar 5, 2003 | 01:07 PM
Sam's Avatar
Sam
Please help!!
Old Mar 5, 2003 | 01:12 PM
1BlackHatch's Avatar
Man for $125 you can get a set of MB quart 6.5" reference series.
Old Mar 6, 2003 | 06:19 PM
ck279's Avatar
Default Re: Is this a good speaker? (1BlackHatch)
"Yes, just $85 included tax for a pair. I use a Sony CDX-MP70 without any amp, is that not a good idea? I just want something better than stock, not real high level component. So, do I need an amp??"
No, you do not need a seperate amplifier. Using a seperate amp would provide you with more clean, full bodied sound. But it is certainly not a necessity. Like you said, your not looking for anything real high level. What you have will be vastly better than stock.
Carl
AWE
(800) 831-5622
[Modified by ck279, 3:20 AM 3/7/2003]
Old Mar 6, 2003 | 09:26 PM
koco's Avatar
There's a seller on Ebay called caraudiowarehouse that sells Eclipse 6.5" coaxs brand new for $53 a pair. They're not the best in the world but they sound alot better than Sony's speakers. But yes, if you can spare $125 you can get MB Quart reference. They will knock your socks off. MB Quarts are among the best. I would totally pass on the Sonys there are better deals out there.
Old Mar 6, 2003 | 09:28 PM
koco's Avatar
With that headunit they should do alright. The headunit amps are pretty strong these days. It'll be loud anyway. Best thing would be to encase the back of the speaker completely.
Old Mar 12, 2003 | 07:28 PM
GTlvr82's Avatar
SONY SUCKS get kicker dx series
Old Mar 12, 2003 | 08:23 PM
b18bEG's Avatar
I will NEVER buy sony car audio..........
Old Mar 12, 2003 | 10:04 PM
Ludester's Avatar
Default Re: Is this a good speaker? (h22akrd)
Yeah i agree sony for the car is junk. Sony tv's and home accessories are good. If you want a head unit go with alpine, kenwood, or pioneer imo. Speakers i like infinity's.
Old Mar 13, 2003 | 12:18 AM
Bubble Gum Jr.'s Avatar
Default Re: Is this a good speaker? (Ludester)
Yeah, I also enjoy Infinities. Since I'm on the lower budget side of the Audio board.
Dave
Old Mar 13, 2003 | 12:32 AM
DA_KengV's Avatar
Might be repetitive, but yea Sony isnt't the best. But anyways, since you bought components you should get an amp to run them because you will get better sound out of them. You might not be looking for the greatest sound, but that is why you have sony's right? So for the price you bougth them for, good deal! If you ever are looking at upgrading and want decent speakers, I would go for Boston Pro Series. Other good speakers are MB Quart, Infinity Perfects, and Alpine's Type-R and Type-X series. Happy listening
Old Mar 13, 2003 | 07:03 AM
rjr162's Avatar
Default Re: Is this a good speaker? (DA_KengV)
my objection to sony speakers would i guess mostly be with the metalic tweeter components... the highs sound very tin-ey to me, and I don't like that. the infinity reference, for example, uses the silk and they sound much more smooth and natural.
KrazoMike
Audio / Security / Video
20
Dec 1, 2011 06:46 AM
fdjizm
Feb 7, 2007 12:22 PM
ApolloSpeed
21
Sep 22, 2005 06:10 PM
is3oo
Sep 5, 2003 08:42 PM
GoLowDrew
May 31, 2001 07:48 AM
