kill switch wire
Old Feb 11, 2002 | 03:54 PM
Aphrodavid's Avatar
Default kill switch wire
im going to install a kill switch on my car. i know that if you disconnect both plugs on the distributor, the motor turns over but theres no spark. which wire can i splice into to install a toggle switch that will let the distributor ignite or not?
if anyone has a better idea on which wire to splice(starter, ignition, etc), or has done their own custom kill switch, let me know how you did it, thx. check my sig for the car info.
Old Feb 12, 2002 | 10:04 AM
virginia_dude's Avatar
Default Re: kill switch wire (DX-R)
Trace down the power to the fuel pump, and wire a hidden switch to that. No fuel, the car ain't driving very far. And it saves the issue of ECU reset if you killed power to the ecu. This will work because its a tank mounted electric fuel pump. Tap in somewhere after the fuse.
Old Feb 17, 2002 | 10:10 PM
crx_91si's Avatar
Default Re: kill switch wire (virginia_dude)
for the fuel pump cut-off, its the solid yellow wire. Check it out. You can get to it by removing the screws on the locking box and looking underneath. There's gonna be 4 wires i think. Just cut the Solid yellow wire and splice a toggle switch or another form of on/off switch in-line with it. Its mad easy and only takes a 1/2 hour and some creativity.
Old Feb 19, 2002 | 06:56 AM
Scary1109's Avatar
Default Re: kill switch wire (crx_91si)
do you have any pics of that in your car, i am looking to do that also.
Thanks
-Scary
LaOXXKIDD
Oct 15, 2009 11:42 AM
Ldo
10
Feb 24, 2009 05:15 PM
96electronH
Audio / Security / Video
Dec 2, 2007 05:29 PM
99fbpem1
Aug 19, 2007 04:23 PM
