<<extra battery for my starter?>>
Old Mar 15, 2003 | 10:06 PM
JOMO
Guest
Posts: n/a
Default <<extra battery for my starter?>>
sometimes when i play my set too long the starter just clicks, like there is not enough power left in the battery , i have an extra battery and im thinkin of putting it in the trunk and using it to start the car, i can wire it all myself, will use 4awg, would you recomend this?
is there a better alternative?
is it easy to wire?
im thinking of just running from the = to the starter and grounding the batt to chassis
i wouldnt want to make my alternater charge it, my friend has an overnight charger so i would recharge it every so often i guess....
thanks
Old Mar 16, 2003 | 06:07 AM
rjr162's Avatar
Default Re: <<extra battery for my starter?>> (JOMO)
good luck. give yourself 3 or 4 starts w/o a recharge and the battery will be dead. Your best bet is just start your car every 15 mins or so when you're listening and let it charge up
Old Mar 16, 2003 | 06:12 AM
JOMO
Guest
Posts: n/a
Default Re: <<extra battery for my starter?>> (rjr162)
rats, i never thought of that, thanks man
yeah but there must be something i can do
Old Mar 16, 2003 | 12:32 PM
vteg's Avatar
New User
Get a deep cycle capable battery. Normal battery lose significant capacitiy each time they are drained. I have lost several batteries over the years this way.
I used to idle my car if I was turning the volume up high. Most alts can get out about 50% of capacity at idle.
Old Mar 16, 2003 | 01:26 PM
JOMO
Guest
Posts: n/a
Default Re: <<extra battery for my starter?>> (vteg)
great, any deep cycle battery will work?
marine?
Old Mar 16, 2003 | 01:54 PM
t0p_sh0tta's Avatar
Deep cycle is a deep cycle from what I understand. Just make sure the CCA's are high enough.
I've heard of a couple of companies like Prostart, Sears, etc... making batteries comparable to the Yellow Top for much less.
Old Mar 16, 2003 | 02:51 PM
vteg's Avatar
New User
I have the svr. Fits perfectly, you just need longer hold down bolts. Most batteries do not fit in the civics/tegs battery spot.
http://www.wholesaleaudio.com/svr.html
Old Mar 16, 2003 | 03:16 PM
JOMO
Guest
Posts: n/a
Default Re: <<extra battery for my starter?>> (t0p_sh0tta)
great, i figured as much, do they make them especially for audio applications in cars?
Old Mar 16, 2003 | 03:33 PM
t0p_sh0tta's Avatar
Yes, check out SVR, Stinger (i think) or Optima, but they are all pretty much the same. What kind of car do you have?
Old Mar 16, 2003 | 03:46 PM
JOMO
Guest
Posts: n/a
i drive a swift, i can fit ant battery size but i doubt i would get those brands, ill look for some tomorrow and ask advice about them, my normal batteriesd are dt=ying after half an hour of bumoing man
Old Mar 16, 2003 | 05:01 PM
HondaDriver4Life's Avatar
If you connect your second battery to the starter, your alternator will still try to charge it. Most stock alternators cannot the handle the extra current demands of charging 2 batteries - it may burn out faster. If you're going to use a 2nd battery, get a good isolator so that your not draining the starter battery while you're enjoying your system with the engine off. An alternative to the isolator are high-current solenoids (or relays) that function the same way (http://www.stingerelectronics.com/st.../batteries.asp). Scroll to the bottom of the Stinger page. You can find a diagram too.
debhawley
Jul 28, 2017 10:01 AM
gooberwolf
Mar 9, 2009 04:11 PM
graphic
Dec 9, 2003 07:17 PM
zcivicz
15
Nov 7, 2003 11:04 AM
Heavy Pee
Jul 21, 2003 08:32 PM
