Entry level system - amp recommendation?
Old Mar 21, 2008 | 12:18 PM
Flar's Avatar
Default Entry level system - amp recommendation?
Hey guys, basically I just want to add a decent amp to my current system, any recommendations? I'm not looking to blow out windows or win any sound competitions (obviously, lol), just get a bit more out of my current speakers.
Here's my setup;
deck: pioneer DEH-2900MP
http://www.pioneer.eu/eur/prod....html
front speakers:
pioneer TS-G650M 6.5" coaxial 3-ways
180W Max.
35W nominal
4 ohm's
rear speakers:
pioneer TS-G960M 6x9 coaxial 3-ways
220W Max.
40W nominal
4ohm's
A powered sub;
JBL "BassPro" 100W like this; http://www.jbl.com/car/product...uct=Y
The speakers are running off stock wires, and are in the factory locations.
I'll need to run new wires if I get the amp, right?
The powered sub is running off an 8 gauge power line from the battery, with the remote turn on lead connected from the HU. It's grounded to a factory hole in the hatch. I have RCA cables running from the HU to the RCA inputs in the sub (although I've been getting alternator whine lately, if I disconnect the RCA's it stops...).
Should I go for a 4 channel, or stick with 2 channel? This is a pretty basic system, so I don't want to spend a crazy amount of money, but I would rather buy something better now and have room to grow.
Thanks for your help!
Old Mar 21, 2008 | 07:19 PM
fcm's Avatar
fcm
Old Fart
Default Re: Entry level system - amp recommendation? (Flar)
If you want more out of your speakers then yes get an amp, you only need a 2ch to drive the front speakers, you can leave the rear speakers connected to the HU.
If you want to step up a little more get a 4ch amp and use the two front channels of the amp to drive the front speakers, [on high-pass] then disable the tweeters on the 6x9s, wire them in series, [for an 8 ohm load] and connect them the the bridged rear channels of the amp, [mixed mono] drive them full range unless the amp has the ability to do low/pass at 5000Hz.
Get some Dynamat, [or the like] and cover the underside of the 6x9 speakers to isolate them from the trunk and the sub.
All the above assumes that the the front and rear speakers are installed properly. 94
Old Mar 21, 2008 | 09:50 PM
Tranceaddict87's Avatar
you don't need to run new wires to speakers that have that little amount of power going to the speakers, there is no need for your purposes.
Old Mar 22, 2008 | 06:05 AM
Flar's Avatar
Default Re: Entry level system - amp recommendation? (fcm)
Thanks for the responses
Hmm.. getting the 4ch. sounds like a better option..
Ok, now what happens to my powered sub if an amp comes into the picture? My HU only has 1 pair of pre-outs, and right now they are going directly to the sub. Does that mean I won't be able to make use of it any more?
Is there a way it can be wired through the 4ch. amp maybe?
Old Mar 22, 2008 | 06:52 AM
fcm's Avatar
fcm
Old Fart
Just find an amp with a set of RCA outputs.
This amp would work great... http://www.pioneerelectronics....6.pdf 94
Old Mar 22, 2008 | 04:00 PM
Flar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Just find an amp with a set of RCA outputs.
This amp would work great... http://www.pioneerelectronics....6.pdf 94</TD></TR></TABLE>
So in this case, wiring (excluding power, remote turn on, grounds) would be something like;
At HU:
HU's 1 pre-out line to amp's RCA IN
At Amp:
Ch.1 &gt; Front, left speaker (wired parallel)
Ch.2 &gt; Front, right speaker (wired parallel)
Bridged Ch.3+Ch.4 &gt; Rears in Series (as you've described earlier).
Amp RCA out &gt; Powered sub RCA in ?
For the remote turn on, i can just use the same wire thats currently going to the sub (i believe its 16g), but just extend it so it branches off to the amp too right?
Old Mar 22, 2008 | 04:28 PM
fcm's Avatar
fcm
Old Fart
That is correct.
You will need to...
Input Select Switch
For two-channel input, slide this switch to the left.
Yes, the remote turn on lead can be daisy chained from one amp to the next, 94
Old Mar 22, 2008 | 06:20 PM
Flar's Avatar
Would using the speaker level input instead of the one RCA IN (from HU to amp) make any difference as far as sound quality goes?
Is there any benefit in general to using speaker level input?
Old Mar 23, 2008 | 07:16 AM
fcm's Avatar
fcm
Old Fart
Amplifying an amplified signal, [speaker level] should not be used if an RCA, [preamp] source is available, SQ will suffer, and you gain no advantage. 94
Old Mar 24, 2008 | 05:17 AM
Flar's Avatar
Great, thanks for all your help fcm! Much appreciated!
hillbillycivic
Audio / Security / Video
Oct 31, 2012 12:19 PM
Cody2289
14
Feb 11, 2008 09:28 AM
pinks11
Nov 19, 2007 07:04 AM
coolrace05
May 26, 2006 05:05 AM
mickey513
Oct 14, 2002 03:01 PM
