eletrical problem
Old Jul 6, 2006 | 09:44 AM
kyorishin's Avatar
Default eletrical problem
alrite the car is a 94 cx hatch and i am running a 1200 watt system. I have the hifonics brutus amp and tthe kicker comp vx. I just recently bought a new battery, now the problem is something is either drainging my battery to quickly or my alternator isnt charging fast enough. heres an example im driving w/o my deck or amp on but the battery line for my amp is connected, my car would barely have enough juice to crank over sometimes or the lights inside would go so dim i could barely see anything. when i do have my deck on with amp driving is koo but when i turn the car off and try to start it back up i get nothing but lights are on inside. Now when i take off the battery line to the amp everythign is perfectly ok. so my question is what the hell is going on, could my amp still be drawing in so much power even when its off? or is my alternator going bad?
Old Jul 6, 2006 | 12:29 PM
94_DC4's Avatar
Default Re: eletrical problem (kyorishin)
Make sure that your remote wire is turning off when your head unit turns off.
Old Jul 6, 2006 | 07:35 PM
suspendedHatch's Avatar
We often get these problems where customers think they have diagnosed and isolated the problem (as you said, unplugging the amp). Most of the time it turns out that the customer's diagnosis was false for whatever reason and it's simply a weak battery or alternator.
You need at least a DVM to check the remote wire as SirGDC suggested. You can also have the battery and alternator tested for free at most auto parts stores. You could have a mechanic measure the amount of current draw when the car is off and compare it to spec.
Old Jul 6, 2006 | 10:52 PM
kyorishin's Avatar
Default Re: eletrical problem (suspendedHatch)
koo will do but up for more info
Old Jul 6, 2006 | 10:58 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
There really not much else to test for you srry. Take mr. hatch advice and go from there. Then you will have a place to start.
Michael.K.Conte
Audio / Security / Video
Jun 6, 2010 06:32 AM
mikej94civex
Dec 30, 2009 02:53 AM
nyzd79
Mar 14, 2008 09:20 AM
GroundZer0 336
13
May 23, 2003 06:10 AM
redteg1
Apr 8, 2002 02:43 PM
