Problem with amp sucking power...
Old Jun 1, 2010 | 08:15 AM
Michael.K.Conte's Avatar
Default Problem with amp sucking power...
sooooo im not the greatest 5-speed driver(im learning lol)
and sometimes i will stall it while my subs are going , and not have enough juice to start up.
i got my car w/ sound installed so i dont really know anything about the setup, or what i should be. but there is a very large gauge wire on the + battery terminal...
I tried searching and found that some people upgrade their alternators/add a second battery, but no one seems to have the same problem i do. also, i think my battery might be a pos...
duralast, its really small compared to most batteries...
Old Jun 1, 2010 | 08:37 AM
clip8907's Avatar
Default Re: Problem with amp sucking power...
what brand amp do you have?
Old Jun 1, 2010 | 09:07 PM
98civdx's Avatar
Master Detailer
Most honda's will have the smaller sized batterys.
A stock charging system is good for about 300 watts rms, so im told.
Have you tried shutting the stereo off when starting it??
Old Jun 2, 2010 | 08:04 AM
my stereo dosent have and off button XD
ill try taking the faceplate off tho
Old Jun 3, 2010 | 04:24 PM
mikekh10a's Avatar
get a bigger battery. i have a yellowtop. has not failed me since
Old Jun 3, 2010 | 04:33 PM
mrdeadman's Avatar
They let me pick
It should cut power to the stereo when you turn the key to III....
Old Jun 3, 2010 | 06:01 PM
fcm's Avatar
fcm
Old Fart
Need more info...
MM&Y of car?
Make and model of HU and amp(s).
When you say, " i will stall it while my subs are going , and not have enough juice to start up" what exactly do you mean?
1-Engine will turn over, [crank] but not start?
2-Engine will not turn over or turns over very slowly and will not start?
Either way^^^ how do you get it started when this happens? 94
Old Jun 5, 2010 | 09:28 PM
02 accord's Avatar
Get out and push start it. Sounds like you have a weak battery. Change that out for a new one and you should be good to go.
Old Jun 6, 2010 | 06:32 AM
got a new battery, all is well thanks guys
03djmAccrd
Jul 9, 2010 12:13 AM
vargas
Audio / Security / Video
Nov 29, 2007 05:58 PM
Birdley42008
Jul 20, 2007 04:07 PM
SD1222
May 11, 2006 06:45 PM
GroundZer0 336
13
May 23, 2003 06:10 AM
