ef door actuator install
Old Mar 3, 2011 | 03:07 PM
dohc4life's Avatar
Icon2 ef door actuator install
ok so i just installed a bmw nitro alarm this one
http://compare.ebay.com/like/1206807...=263602_304662
and it works great and i ordered this 2 wire door actuator
now on the wiring diagram for the alarm it has 2 wires for the door actuators
so im wondering if the relay is built in or not and if not how do i wire them up? this was my first alarm install and i have searched so i just wanna know before the actuator gets here. thanks in advance this is the door actuator
http://www.amazon.com/Absolute-DLA11.../dp/B002Y31ANW
Old Mar 3, 2011 | 06:59 PM
fcm's Avatar
fcm
Old Fart
Default Re: ef door actuator install
You will need relays, [two (2) SPDT relays] the two leads out of the alarm that are for door locks, [probably green and blue] are low current grounds, you will yous them to control the relays, wire like this, Actuators/Reversing Polarity... http://www.the12volt.com/doorlocks/page3.asp#arp
This is a pretty good read also... http://www.the12volt.com/relays/relays.asp 94
Old Mar 3, 2011 | 11:31 PM
dohc4life's Avatar
thank you for the quick reply.
funny because i was just reading someone elses post sort of like mine and you helped them out. and the lock out put is green/black negative and the unlock output is blue/black idk if that makes a difference. thanks again though
Old Mar 4, 2011 | 05:56 AM
fcm's Avatar
fcm
Old Fart
The most common colors for low current door lock outputs is green and blue but it is not universal, because there are only 2 leads for the door locks they can only be low current outputs, the color, [black tracer] will not make a diff. 94
buff1110
Audio / Security / Video
Apr 17, 2010 05:17 PM
sickofitall1113
May 6, 2007 05:01 PM
EJ8 GSR-T
11
Apr 29, 2007 03:35 PM
the jdmchop
May 10, 2006 08:40 AM
LoveOfMoney
Apr 1, 2006 12:07 PM
