keyless entry help
Old Mar 31, 2006 | 11:47 PM
LoveOfMoney's Avatar
Default keyless entry help
im getting ready to install a clifford rsx 3.5 alarm and was wondering if it is easy to install power door actuators. Will i need a seperate relay and if so how many? or i can just plug it into the alarm??
Old Apr 1, 2006 | 05:08 AM
B18C_EJ8's Avatar
Into which car are you planning to install them?
And yes, you will need relays, and no you cannot plug them into your alarm.
Old Apr 1, 2006 | 09:34 AM
89 crx dx, how much relay will i need?
Old Apr 1, 2006 | 12:07 PM
fcm's Avatar
fcm
Old Fart
Default Re: (LoveOfMoney)
What you need will depend on what you put in for door lock actuators, normally the least expensive way is to install a 2 wire actuator in each door, run the 2 leads from each door the the same spot under the dash or one of the kick panels, there you will need to install 2 SPDT relays, [one for lock and one for unlock, and wire them like this... http://www.the12volt.com/doorlocks/page3.asp#arp
The other way to go is with a "Central" locking system, they come is diff. configurations, but all will come with at least 2 actuators, [one 2 wire and one 5 wire, (drivers door)] and a "black box", [relay and circuitry box] a 5 wire actuator has a switch in it that sends a lock or unlock signal to the "black box" the "black box" then locks or unlocks the other door. EG: if you lock the drivers door with the key or the manual door lock button it will also lock the pass. door, if both actuators are 5 wire, then locking or unlocking the pass. door will also lock or unlock the drivers door, [Central Locking], the "black box" will also have, [at least] a set of low current neg. (-) inputs, [for the door lock outputs from the Matrix RSX 3.5.
The advantage of a central locking system, [especially one with 2 five wire actuators] is you can lock and unlock both doors using a key or the stock manual door lock buttons, [no switch's have to be installed] and the polarity reversing relays are already wired, [black box] 94
19josh91
Sep 1, 2013 01:34 PM
r3dfish
15
Jan 24, 2013 05:41 PM
dohc4life
Audio / Security / Video
Mar 4, 2011 05:56 AM
the jdmchop
May 10, 2006 08:40 AM
Average DA9
Aug 17, 2004 07:27 PM
