ECU Kill switch....
Old May 16, 2003 | 08:57 AM
SloCivicHMM's Avatar
Default ECU Kill switch....
Is there a way to cut power from the ecu???
What wire??
I'll be adding a few kill switches to my ride.....fuel and starter....should I just add a switch or your a relay??
Old May 17, 2003 | 11:46 AM
projecthybrid04's Avatar
Default Re: ECU Kill switch.... (SlowCivicHmm)
im interested too
Old May 17, 2003 | 12:01 PM
t0p_sh0tta's Avatar
Default Re: ECU Kill switch.... (projecthybrid04)
Doesn't the ecu have two power sources? The main and a backup?
Old May 17, 2003 | 09:15 PM
9200RPM's Avatar
If you have a viper alarm or keyless, you can use the alarm to trigger this....use the orange wire (its grounded when armed) and hook it up to a relay that breaks the constant to the ecu power...i dont know the pin out to the ecu but you might be able to find that at allmotorhonda.com...good luck...PM me if you have any questions
Old May 18, 2003 | 08:43 PM
Xsi's Avatar
Xsi
If you disconnect the constant power to the ECU, wouldn't that reset it every time you arm it?
Old May 18, 2003 | 10:14 PM
Default Re: (Xsi)
never thought about it that way..hmmm
I guess it would.......well if there is 2 power sources if I cut on then the other works correct?? but are both connected to the same fuse?? cuz if I pull the fuse out to reset my ecu then it should stil have the back up power correct??
Hmm, makes me think if this is possible or not...
Old May 19, 2003 | 10:10 AM
Default Re: (StreetRacnGsR)
sweet I'll have to get one..
Know where I can find them online??
Old May 19, 2003 | 12:38 PM
StreetRacnGsR
Guest
Posts: n/a
Default Re: (SlowCivicHmm)
well you want to buy a kit? cause i have one that i built and havent put in my car yet well acually i have 3 kits made up. if you want it i will sell it for 20 bucks shipped. i think its worth 20 bucks so your car wont get stolen.
Old May 19, 2003 | 01:03 PM
how easy is it to hook up?? something I can do myself, I'm not good at wiring stuff, especially electrical...but I'm really serious....let me know..
Old May 19, 2003 | 01:11 PM
StreetRacnGsR
Guest
Posts: n/a
well with my kit all you have to do is find 2 wires in your car and hook it up and your set.
Old May 19, 2003 | 01:27 PM
what comes in the kit??
Old May 19, 2003 | 08:42 PM
9200RPM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowCivicHmm &raquo;</TD></TR><TR><TD CLASS="quote">sweet I'll have to get one..
Know where I can find them online??</TD></TR></TABLE>
Unless you access to 12v relays it will be a lot easier to buy the kit...
Old May 19, 2003 | 08:48 PM
StreetRacnGsR
Guest
Posts: n/a
Default Re: (TurboB16aEG)
Yeap i have the kits made up if anyone wants them.. Also working on another kit but adds fuel pump cut off.
Old May 19, 2003 | 09:42 PM
I'm definate in for the kit.....fuel cut off huh?? let me know about that one.....the more the security the better...haha
Old May 19, 2003 | 10:56 PM
StreetRacnGsR
Guest
Posts: n/a
Id try Im you but you didnt answer. If anyone is intrest in it act fast. i hook one up today works great and i try to start it under the hook cause you can jump it and couldnt do it i am ever happy with the design. I have 4 kits left.
$25 shipped anywhere in the US.
$25 is worth saving your car.
Old May 20, 2003 | 07:29 AM
u have a pm!!
Old May 20, 2003 | 04:00 PM
StreetRacnGsR
Guest
Posts: n/a
Bump anyone want to save there car? i have kill switch systems for any car.
Old May 20, 2003 | 09:36 PM
9200RPM's Avatar
Default Re: ECU Kill switch.... (StreetRacnGsR)
fuel pump kill is also very good... i have that along with ecu kill triggered by my alarm....althought i dont think anybody has tried to steal my car...it would deter them enough to where they would just do minor damage...
Old May 20, 2003 | 10:18 PM
StreetRacnGsR
Guest
Posts: n/a
Default Re: ECU Kill switch.... (TurboB16aEG)
who did you set it up to kill your fuel pump? i wanna wire a system for both starter,ignition and fuel pump.
Old May 20, 2003 | 10:19 PM
drumking15's Avatar
you gonna have these in a couple weeks?
Old May 20, 2003 | 10:22 PM
StreetRacnGsR
Guest
Posts: n/a
Default Re: (drumking15)
yes i will have these. i have a shipment of 30 relays to make more kits..
Old May 21, 2003 | 07:19 AM
Let me know when you get the fuel pump kill intergrated with the started killer and I'll send ya a money order.......
So you said even if they push start it, it won't work?? or even jump start??
Old May 21, 2003 | 03:01 PM
StreetRacnGsR
Guest
Posts: n/a
yes we try it on two hondas so far and it works great the add of a full pump kill will be more cause of materials used. i am working on it this weekend. i dunno when they will be avaible to buy them.
Old May 21, 2003 | 05:34 PM
well hit me up when you do...Cuz you have a definate customer, I even wrote the check out already......but i"ll wait for the upgraded model...lol
6pak for you dawg!!
Old May 21, 2003 | 05:47 PM
StreetRacnGsR
Guest
Posts: n/a
Ok. I found it out.. i will work on it tomarrow but you will need to add wire to the fuel pump and tap into it. i will repost up tomarrow on it.
