ECU Kill switch....
Old May 21, 2003 | 06:05 PM
  #26
nsxxtreme's Avatar
Default Re: (StreetRacnGsR)
Or build your own http://www.the12volt.com/relays/page2.asp
Old May 21, 2003 | 07:19 PM
  #27
StreetRacnGsR
Guest
Posts: n/a
Default Re: (nsxxtreme)
To bad they dont have a fuel pump kill switch system. thats the most inportant one.
alot of people can get past the ignition kill switch. starter kills are a little harder and add a fuel pump kill to them both and your car will be impossible to get.
Old May 21, 2003 | 08:27 PM
  #28
nsxxtreme's Avatar
So instead of connecting it to the starter connect it to the fuel pump. Cut the fuel pump wire and instead of connecting to the starter wires you connect it to the fuel pump wires.
No immobilization is impossible to get past. Point me to your brain and I could disable all of your relay immobilizations in about 30 sec.
The idea of hooking them up to something else is so that all the wires do not run back to the alarm. This way if someone was able to locate the alarm hopefully they wouldn't locate the wires going to the fuel pump cutoff.
Old May 21, 2003 | 09:25 PM
  #29
StreetRacnGsR
Guest
Posts: n/a
I have the fuel pump kill switches done. need one. they are two differant kill switches. IM me for more details
Old May 22, 2003 | 12:43 AM
  #30
Calavera's Avatar
excellent! you got IM.
Old May 22, 2003 | 12:22 PM
  #31
StreetRacnGsR
Guest
Posts: n/a
Default Re: (Calavera)
Hi, I Sent you a IM and I have 5 each of Both the Fuel Pump Kill switch and Starter kill switch. I will sell the Fuel pump kill with everthing you need ( You may need to add some wire depending on where you put the kit) for $20 Shipped and the starter kill for $25 shipped in the US. IM ME for more details. Both are installed on my ride and work.
Old May 22, 2003 | 12:23 PM
  #32
StreetRacnGsR
Guest
Posts: n/a
Bump Good way to save your car.
Old May 22, 2003 | 02:05 PM
  #33
SloCivicHMM's Avatar
how much for both?? and they work together?? to the same switch??
Old May 22, 2003 | 05:28 PM
  #34
Bigjon
Guest
Posts: n/a
Default Re: (SlowCivicHmm)
StreetRacnGsR how about you post what is all included in this wonderfull kit. a toggle switch and some relays?? If I was any of yall that are about to buy his "kit" I would do some research first to make sure that you arent gettin ripped off
Old May 22, 2003 | 07:31 PM
  #35
StreetRacnGsR
Guest
Posts: n/a
Default Re: (Bigjon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bigjon &raquo;</TD></TR><TR><TD CLASS="quote">StreetRacnGsR how about you post what is all included in this wonderfull kit. a toggle switch and some relays?? If I was any of yall that are about to buy his "kit" I would do some research first to make sure that you arent gettin ripped off</TD></TR></TABLE>
well the toggle switches are all metal and a great qauilty switch. and the kit is well worth the money to save your car or you could end up not having a car cause of a theive.. I will let both of them go for 40 for both shipped in the US. if you wanna make the kit then relays are about 10-14 each which the start kill uses 2 relays and the fuel pump kill uses 1 relay. thats up to 32dollars just for the relays.
IM ME if you would like to purchese these.
Old May 23, 2003 | 02:35 AM
  #36
Bigjon
Guest
Posts: n/a
2 12VDC BOSCH RELAY SPDT 30A This 12V, 30A relay from http://www.partsexpress.com
4$
1 metal toggle switch from http://www.partsexpress.com
.95$
ripping off fellow honda-tech members
priceless
seriously there is nothing magical or hard to get about relays. I'll sell yall the same exact thing he is selling you guys for 8$ including shipping and i am still making 100% profit. If you have the skills to install this"kit" then you have the skills to make it yourself. check out all the other hundreds of kill switches threads on this board and check out http://www.the12volt.com
Plus if your selling **** it should be in the classified forum
Modified by Bigjon at 9:49 AM 5/23/2003
Old May 23, 2003 | 08:29 AM
  #37
StreetRacnGsR
Guest
Posts: n/a
Dont be coming on here to try to steal buisness. and thats just not the same as my kit considering someone has the kill switch and is very easy to get. the moderater will be seeing this and i reported you. thank you have a great day.
Old May 23, 2003 | 08:35 AM
  #38
StreetRacnGsR
Guest
Posts: n/a
Also you need 2 relays so it dont work on your alarm. and what about shipping i have 19dollars in these kits plus shipping which is about 3-5 in the US. I aint making nuttin really. I just wanna help out the people that dont have that much experience and you need to Soder your wiring so it dont come apart. Anyone intrested IM ME.
Old May 23, 2003 | 08:37 AM
  #39
Bigjon
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bigjon &raquo;</TD></TR><TR><TD CLASS="quote">StreetRacnGsR how about you post what is all included in this wonderfull kit. </TD></TR></TABLE> Where is this 19$ comming from? All I'm trying to do is help the people that don't have much experience make thier own kill switches for a few bucks.
Old May 23, 2003 | 08:40 AM
  #40
slowaccord
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRacnGsR &raquo;</TD></TR><TR><TD CLASS="quote">Dont be coming on here to try to steal buisness. and thats just not the same as my kit considering someone has the kill switch and is very easy to get. the moderater will be seeing this and i reported you. thank you have a great day.
First of all, He was trying to educate his fellow honda-tech members on how to do-it-themselves.
Second, Your product is an outright RIP-OFF.
Third, Your butchering of the english language is simply disgusting,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRacnGsR &raquo;</TD></TR><TR><TD CLASS="quote">well the toggle switches are all metal and a great qauilty</TD></TR></TABLE> quality
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRacnGsR &raquo;</TD></TR><TR><TD CLASS="quote">and the kit is well worth the money to save your car or you could end up not having a car cause of a theive.. </TD></TR></TABLE> thief
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRacnGsR &raquo;</TD></TR><TR><TD CLASS="quote">IM ME if you would like to purchese these.
</TD></TR></TABLE> purchase
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRacnGsR &raquo;</TD></TR><TR><TD CLASS="quote">Ok. I found it out.. i will work on it tomarrow but you will need to add wire to the fuel pump and tap into it. i will repost up tomarrow on it.</TD></TR></TABLE> tomorrow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRacnGsR &raquo;</TD></TR><TR><TD CLASS="quote">Dont be coming on here to try to steal buisness</TD></TR></TABLE>business
I'm too tired to go on, although i'm sure i could find more.
Old May 23, 2003 | 08:42 AM
  #41
Bigjon
Guest
Posts: n/a
Default Re: (slowaccord)
anyone interested on how to do this yourself for a fraction of the price IM ME
Old May 23, 2003 | 08:44 AM
  #42
Well I'm still interested......you guys need to chill, to each of his own right?? But by looking at your post numbers, I understand the cockyness.....HT is a family and friends.....calm down....no harm no foul.......
Old May 23, 2003 | 08:45 AM
  #43
Bigjon
Guest
Posts: n/a
that is why I am trying keep people from getting ripped off. F the post numbers. I am just trying to help you guys out.
Modified by Bigjon at 6:04 PM 5/23/2003
Old May 23, 2003 | 08:49 AM
  #44
slowaccord
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bigjon &raquo;</TD></TR><TR><TD CLASS="quote">anyone interested on how to do this yourself for a fraction of the price IM ME</TD></TR></TABLE>
Bump, save yourself some money and learn a little while you're at it.
Old May 23, 2003 | 08:50 AM
  #45
StreetRacnGsR
Guest
Posts: n/a
You will have to remeber if you are building the kit to use a sodering gun so none of your connections come apart on you. http://www.Snapon.com have them for sale. i work at a computer chipping place in oregon and i do all the work there with all the right tools to ensure the best quailty. but if you would like to make the kit feel free you have that right. You might beable to get all the stuff at a local autoparts store too. but on the west coast the relays are 8-13 bucks each. http://www.the12volt.com has a ok starter kill but can easyly be bypassed.
Old May 23, 2003 | 08:52 AM
  #46
hybridmoose's Avatar
Personally I would like to know what you reported Bigjon for? Perhaps you reported him for telling the truth? By reporting him you also reported yourself.
I highly doubt that any moderator would have anything negative to say about a H-T member looking out for his fellow members!
Its is absolutely absurd for you to think that you are in the right when you are clearly ripping people off!
I have both sides in this argument and gone to the links provided by Bigjon and from what I have seen you sir have been owned and shown to be nothing more than a thief yourself!
Another thing. I would like to know what the hell post numbers have to do with someone trying inform people that they are being ripped off??? Calm me crazy but that has no bearing on this arguement.
Old May 23, 2003 | 09:21 AM
  #47
StreetRacnGsR
Guest
Posts: n/a
Default Re: (hybridmoose)
Who is the thief? <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> would like to know what the hell post numbers have to do with someone trying inform people that they are being ripped off??? Calm me crazy but that has no bearing on this arguement.</TD></TR></TABLE> I would like to know also how post numbers can detected a thief.....
Old May 23, 2003 | 01:54 PM
  #48
Bigjon
Guest
Posts: n/a
who cares what the f post numbers have to do with who is a thief and who isn't. the FACT is that you have not posted what is involved with these kit for all of us to see. Also I have prooved that unless you got ripped off on relays you are charging fellow honda-tech members WAY too much for the "kits" that these people could easily build themselves. And to anyone in the MD/DC/NOVA area I would be glad to build and install a "kit"(BULLSHIT) that would accomplish that same thing that StreetRacnGsR's kit does for 1 6-pack of Newcastle Brown Ale.
And who the f is calling who a thief? I have tried to sell nothing except the same thing you have but sarcastically. Other than that I have offered nothing but information for free for other honda-tech members.
StreetRacnGsR you need to quit trying to make a quick buck off honda-tech members by trying to sell some gay kit. I would also like to make it clear that if you paid WAY too much for relays then this whole argument is moot, and I apologize for accusing you of trying to rip people off, when in fact you got ripped off.
The FACTS are that any other member of this websit that has full use of one of thier hands can build, design and install thier own kill switch with the help of the search button on this website and about 6 dollars.
So go ahead and report me to the mods, and make sure you make it clear to them about how all I was trying to do was help out my fellow honda-tech members.
Like I said before, if anyone wants to know how to to build, design and install thier own customs kill switches then IM ME and I will give you all the help you need for FREE like every other honda-tech member on here should do.
Modified by Bigjon at 6:31 PM 5/23/2003
Old May 23, 2003 | 02:20 PM
  #49
Bigjon
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRacnGsR &raquo;</TD></TR><TR><TD CLASS="quote">You will have to remember if you are building the kit to use a soldering gun so none of your connections come apart on you. http://www.Snapon.com have them for sale.</TD></TR></TABLE>
Riiight and radio shack also has soldering guns for sale for 6 dollars that will work, and if you know how to do it crimp connectors will work just as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRacnGsR &raquo;</TD></TR><TR><TD CLASS="quote">i work at a computer chipping place in oregon and i do all the work there with all the right tools to ensure the best quailty. but if you would like to make the kit feel free you have that right. .</TD></TR></TABLE>
I work for the United States Navy primarily as an Avitation Electronics Technician and ONE of the many things I have been trained for is soldering and the Navy has the only certified soldering school there is, and i have been to it and i can do the same **** soldering wire connections in my driveway with my 6 dollar radio shack soldering iron in my car that I can do at work with 6 thousand dollar soldering station at work. YOU ARE SOLDERING TOGETHER WIRES, NOT CHIPS TO CIRCUIT BOARDS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRacnGsR &raquo;</TD></TR><TR><TD CLASS="quote">You might be-able to get all the stuff at a local autoparts store too. but on the west coast the relays are 8-13 bucks each.</TD></TR></TABLE>
BULLSHIT, QUALITY BOSCH RELAYS are 1.99$ at http://www.partsexpress.com. I am pretty sure that they will ship, not only to the east coat but also the west coast. So if you got ripped off on relays dont try to make your money back by trying to rip off honda-tech members.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRacnGsR &raquo;</TD></TR><TR><TD CLASS="quote">http://www.the12volt.com has a ok starter kill but can easyly be bypassed.
Then why dont you post what is included in the wonderfull "KIT" that you are selling. Then maybe those of us who know about electronics will realize why you are charging so much for your "kit"
Old May 23, 2003 | 03:56 PM
  #50
StreetRacnGsR
Guest
Posts: n/a
WHOA Navy dude LoL. I already have saved my cuzin car once from the kit but if any of you want to go do the kit make sure its done right cause if your car goes down the road and the fuel pump dies cause you didnt do it the right way and you crash.. that would suck. plus thiefs know what relay look like and find them. mine all in a little box and only the wires come out and are all one color to confuse them if they see it but good luck to all that do this. Also one tip you need for the fuel pump a 10amp switch and i payed 5 bucks at the local autoparts cause i didnt wanna risk ordering it online and waiting... Partsexpress wants 4.95 and up shipping so eigher way its about the same to build the kit after you buy the radio shack sodering gun and everthing. and for 6 bucks the gun sucks i used to have one when i was like 14 lol
