Eclipes deck help
Old Aug 1, 2006 | 09:33 PM
tchen415's Avatar
Default Eclipes deck help
Hey i have a eclipes deck, When i installed iti noticed extra blue and a orange wire. My honda harness didnt have those wires so i didnt think i needed it. Its a weird deck. Has this ling wire and the end of it has a metal box. I have no idea what it is, Right when i turn it out it says "help" then displays a code. Well its kinda late to call the 1800 number so i guess il try tomorrow. But does anyone know what the problem is?
Old Aug 2, 2006 | 04:10 AM
B18C_EJ8's Avatar
The extra blue wire is a remote turn on for an amp. If not used, this should be capped off.
The extra orange wire is the illumination wire. If not used, this should be capped off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Has this ling wire and the end of it has a metal box. </TD></TR></TABLE>
WTF is a ling wire?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Right when i turn it out it says "help" then displays a code</TD></TR></TABLE>
It's asking for the security code that was set up. Without the code, it will not turn on. If you do not remember (or do not know) the code, then it will require servicing at Eclipse or an authorized service center to reset it.
Old Aug 2, 2006 | 09:45 AM
02 accord's Avatar
Default Re: (B18C_EJ8)
I think he meant long wire. The box at the end of it would be a dc-dc converter.
Old Aug 2, 2006 | 10:19 AM
B18C_EJ8's Avatar
Ohhhh... Gotcha....
I never did understand why Alpine & Eclipse put those damn things on their decks... I mean, every other company seems to work well without them... What purpose do they serve???
Old Aug 2, 2006 | 12:18 PM
02 accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">What purpose do they serve???</TD></TR></TABLE>
The dc-dc converter? To increase the voltage for the output amp. The converter being in a separate box? To keep the interference away from the audio circuitry inside the headunit.
Old Aug 3, 2006 | 02:07 PM
8520's Avatar
Default Re: (02 accord)
On most of the higher end eclipse decks you can actually turn off the display to even further reduce noise
Old Aug 3, 2006 | 07:27 PM
02 accord's Avatar
Default Re: (a_s_ol_)
I can do that on my alpine cda9855. And I have the external dc-dc converter too.
Old Aug 3, 2006 | 10:16 PM
8520's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">I can do that on my alpine cda9855. And I have the external dc-dc converter too.</TD></TR></TABLE>
But you also have glide touch
Old Aug 3, 2006 | 10:18 PM
02 accord's Avatar
I don't mind it. Not the easiest to use while driving, but it works.
Old Aug 4, 2006 | 10:55 AM
8520's Avatar
Suprised you don't have one of the older alpines like a 9835.
Jordan8742
Audio / Security / Video
Mar 25, 2015 09:19 AM
MG-Honda
Nov 30, 2011 10:16 AM
fergs96integra
23
May 22, 2006 09:17 AM
sooo_slow
Feb 28, 2005 03:21 PM
mikecivichb
Apr 4, 2004 10:05 AM
