Dome Light!
Old Jul 22, 2005 | 04:59 AM
01Blackerado's Avatar
Default Dome Light!
Wierd dome light problem! I open the doors...no light. I click the alarm key...light comes on then goes off after inserting the key or 5 min. Why wont it work when i open the door? The light that says the door is open, in the dash, works just fine but the dome light wont come on with it. Any suggestions?
Old Jul 22, 2005 | 08:35 AM
jb.'s Avatar
jb.
Default Re: Dome Light! (01Blackerado)
did you check your light switch on the dome light, on my 95 accord, there are 3 diff settings, off all of the time, on when the doors open, and on all of the time
Old Jul 22, 2005 | 10:01 AM
Yep the switch is good to go
Old Jul 22, 2005 | 10:50 AM
LudemanDan's Avatar
Default Re: (01Blackerado)
Probably the switch in the door jamb is stuck down. Pull it out and see if the light comes on.
Dan
Old Jul 22, 2005 | 11:23 AM
I'll check and see
Old Jul 22, 2005 | 12:45 PM
rjr162's Avatar
Default Re: (LudemanDan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudemanDan &raquo;</TD></TR><TR><TD CLASS="quote">Probably the switch in the door jamb is stuck down. Pull it out and see if the light comes on.
Dan</TD></TR></TABLE>
My guess is this isn't going to be it if the light on the dash works fine. Is the alarm that's installed an aftermarket, or is it a factory setup?
Old Jul 22, 2005 | 05:09 PM
Aftermarket, Viper Alarm...and no it wasnt the door switch
Old Jul 22, 2005 | 05:59 PM
NVturbo's Avatar
O.G. triple O.G.
I believe your domelight was hooked up as "domelight supervision" which means it comes on when you insert/remove your keys. You might have left out a wire that keeps the light on or maybe the alarm you have does not have that feature to keep the light on when the door(s) are open.
user 8508202243
Apr 29, 2012 03:33 PM
zsudz922
Audio / Security / Video
Oct 1, 2009 02:21 PM
zsudz922
Sep 25, 2009 08:25 AM
amej8
Feb 8, 2006 08:46 PM
bigslimdog
Sep 4, 2005 09:49 AM
