Compustar alarm system
2003 Honda Civic
Compustar- 2wssr
I am unable to disable the passive arming feature of my alarm system...dangerous feature when you only have 1 key...do u guys need any more info than this??
Compustar- 2wssr
Found this for another 2W unit on their website.. no clue if it applies to that model:
Active Lock/Arm and Unlock/Disarm
Tap button for 0.5 second to lock/arm and unlock/disarm. The LED will flash on your remote. If your vehicle is locked, tap button to unlock; if your
vehicle is unlocked, tap button to lock.
IMPORTANT: If the alarm has been triggered (Siren is going off), you must wait up to 5 seconds before disarming the alarm - the first button tap will
shut off the alarm and the second will unlock/disarm the system.
Passive Lock/Arm
The system can be configured to passively lock and arm the vehicle. Put the system in passive by tapping buttons simultaneously for 0.5 second.
The remote will beep once and the LEDs will illuminate to indicate the system is in passive lock and arming mode.
While in passive mode, the system will lock and arm the alarm 30 seconds after the last door is closed. As an indicator that the vehicle is going to passively lock
and arm, the remote and siren will chirp once and the parking lights will flash once at both 10 and 20 seconds prior to passively locking and arming. If you want
the system to passively arm and not passively lock, ask your local Firstech dealer to turn Option 1-8 to setting I
Haven't worked with Compustar units yet (though I'd really love to pick them up since the CM6200 + Idatalink Blade units are a sweet combo!!) so I can't tell you how to get into that menu feature as each brand is different (IE> Audiovox Prestige units you turn the key on, hit the programming button 3 times, and then turn the ignition off/on either once or twice to get into different menus, and then press the button "X" # of times to get o the feature within that menu. DEI units, you turn the key on, then off, and hit and hold the button to get to the menu you want and then press the button "X" # of times and hold to get the feature within that menu)
Passive Lock/Arm
Press buttons II and III for 1/2 sec. to turn passive arming on or off.
There are two passive arming modes, with passive locking and without passive locking, you must go to programming to select which mode you want.
Here is the owners user guide... http://www.compustar.com/ownerscorne...SSR_manual.pdf 94
REDEM1FTW
Audio / Security / Video
Jul 7, 2011 10:46 PM
