COMPUSTAR 2W900FM-AS install help
Old Mar 15, 2006 | 09:32 AM
DC2 to AP2's Avatar
Default COMPUSTAR 2W900FM-AS install help
ok im installing alarm and need some help on what wires need to be hooked up and dont need to be hooked up. i dont care for the auto-start, but i do want the turbo timer feature to work.
can someone tell me where to find the wires and possibly what colors they are? thanks!
COMPUSTAR MODEL: 2W900FM-AS (AUTO-START)
CAR: 93 CIVIC SI
CN1
1. red: (+)12v constant - white wire on the ignition
2. green/white: parking light - plugged to empty fuse box location
3. red/white: (+)12v constant prewired relay for 2nd IG, ACC, or STARTER - ?
4. white: accessories - black/? on the ignition harness
5. violet: starter kill/anti-grind - ?
6. yellow: starter - ?
7. green/red: ignition
8. black: ground - ground to chassis
CN2
1. green/white: (-)light output 250mA - ?
2. black: (-)status output 250mA - ?
3. green: (-)ignition output 250mA - ?
4. white/black: (-)accessory output 250mA - ?
5. red/black: (-) starter output 250mA - ?
CN3
1. light blue: (-)e-brake sensing - green/red wire on ebrake handle
2. gray/black: (-)hood sensing - hood pin
3. light blue/white: (+)brake sensing - ?
4. violet/black: (-)trunk sensing - ?
5. red/white: (-)door sensing - ?
6. red: (+)door sensing - ?
7. brown/black: (-)glow plug - ?
8. brown/white: (+)glow plug - ?
9. yellow/black: engine sensing - ?
CN4
1. none
2. violet/white: (-)trunk unlock 250mA - ?
3. orange black: (-)2nd pulse unlock 250mA - ?
4. blue: (-)unlock 250mA - ?
5. blue/black: (-)lock 120 mA - ?
6. none
CN5
1. orange: (-)rearm 250mA - ?
2. orange/white: (-)disarm 250mA - ?
3. violet: dome light supervision 250mA - ?
4. brown: (+) siren - red wire off the siren
5. white: horn 250mA - ?
6. yellow: (-)aux 1 250mA - dont need
7. yellow/white: (-)aux 2 250mA - dont need
8. none
CN6
LED light plug-in
CN7
shock sensor plug-in
CN9
optional sensor
CN10
temp sensor - ???
CN11
antenna plug-in
CN12
tach switch learning ?
DIP ?
JUMPER ?
Old Mar 15, 2006 | 09:40 AM
fcm's Avatar
fcm
Old Fart
Default Re: COMPUSTAR 2W900FM-AS install help (imola-red dc2)
IMed 94
Old Apr 3, 2007 | 02:26 PM
itsJDMyo's Avatar
Default Re: COMPUSTAR 2W900FM-AS install help (fcm)
back from the dead, i'm having the same problem figuring out how to install it. any help here?
ryaned380
Audio / Security / Video
Dec 12, 2019 06:06 AM
tr666
Sep 11, 2012 06:43 PM
Asmar
Feb 1, 2012 06:18 AM
Matt93eg
13
Jan 11, 2010 08:24 AM
DC2 to AP2
Jan 11, 2005 12:13 PM
