Is this compatible?
Old Apr 15, 2007 | 05:18 PM
xBlackMikex's Avatar
Default Is this compatible?
I bought 2 dual voice coil MTX T5512-44 12" subs. Along with that, I also bought 1 MTX mono block Thunder 5601 amp.
Now, for my question....
The subs are both 300RM, 4 ohms. The amp is 300 watts x 1 @ 4 ohms / 600 watts x 1 @ 2 ohms.
What I am lost on is since this is not a single coil sub will it still work with this setup? If so, how would I need to wire it.
Thanks
Old Apr 15, 2007 | 05:36 PM
RaysBoomBoomLude's Avatar
Default Re: Is this compatible? (xBlackMikex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xBlackMikex &raquo;</TD></TR><TR><TD CLASS="quote">I bought 2 dual voice coil MTX T5512-44 12" subs. Along with that, I also bought 1 MTX mono block Thunder 5601 amp.
Thanks</TD></TR></TABLE>
you can run it, run them in parallel, itle cut the OHMS to 2.
Old Apr 17, 2007 | 10:44 PM
Default Re: Is this compatible? (RaysBoomBoomLude)
So that'd make it to 2 ohms right? I thought that would cut it down to 1 ohm. Just want to be sure because I'll be installing this today. Thanks.
Old Apr 18, 2007 | 01:13 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Sorry but you should have got the svc 4 ohm voice coil. Your not going to get a single 2 ohm load with 2 dvc 4 ohm. The lowest your going to get is 1 ohm and your amp can not handel that. Or a 4 ohm load which is going to underpower your speakers.
Old Apr 18, 2007 | 03:42 AM
Default Re: Is this compatible? (wrx-killer-Sti eater)
Thanks! I just wanted to be sure .
Just to be sure the Alpine Type-R 12s (model 1222d) DVC would work right? They are 2 ohms each sub.
Old Apr 18, 2007 | 05:59 AM
fcm's Avatar
fcm
Old Fart
Although the Alpines will work, you do not have enough power to drive them properly, the Alpine SWR-1222D are DVC 2 ohm 500W continues 1500W peak
You would need an amp that makes 1000W RMS into 1, 2 or 8 ohms.
If you already have the amp, find two 300W SVC 4 ohm subs or two 300W DVC 2 ohm subs, better yet, find two 250W-275W subs a little overpowered is a good thing, can you say headroom? 94
cmwright1986
Audio / Security / Video
Dec 3, 2006 10:57 PM
rockin_remz
10
Mar 14, 2006 06:36 PM
Synergy001
Jun 26, 2005 05:14 PM
Itz Darave
17
Jul 19, 2003 01:30 PM
Jan 31, 2002 10:43 AM
